98 accord door lock-window switch problem-multiplex master window switch?
Old Oct 20, 2005 | 11:18 AM
mgerdes's Avatar
Default 98 accord door lock-window switch problem-multiplex master window switch?
i have a new question, hope this is the place for it. my 98 accord s keyless (dealer installed) entry quit working. here are the symptoms:
remote only unlocks the drivers door, wont lock it again
master window switch only works the two left windows. right windows work from their own switch.
door locks dont work from anywhere or with the key, except manual operation
lights and horn work from the remote as normal, just nothing happens with the locks.
thanks for your help. mark in texas
Old Oct 20, 2005 | 07:07 PM
gianinline's Avatar
Could be something with the wiring from the main switch on driver's door.... that's my guess.... electrical problem!
Old Oct 20, 2005 | 08:40 PM
Honda_Accord's Avatar
Default Re: 98 accord door lock-window switch problem-multiplex master window switch? (mgerdes)
ya i agree definatly electrical.. obviously.. do u have a warranty on it or anything?
Old Oct 22, 2005 | 03:26 AM
mgerdes's Avatar
Default Re: 98 accord door lock-window switch problem-multiplex master window switch? (Honda_Accord)
honda-tech, help???
Old Oct 22, 2005 | 07:25 AM
P_Adams's Avatar
Mark, The first place I'd start is at the fuse box. I don't expect to find any, but I want you to first confirm all the fuses are ok.
From there, I'd check the connections to the L/S Front Master Switch Assembly (Both the Windows and door locks work thru it).
What's making it tough for both myself and anyone else who might want to jump in here, is that it'e an add-on (Dealer Installed) item; and we've no idea where they may have intercepted required wiring, or what system it is.....Honda Accessories or AfterMarket...
It could be something as simple (Hah!) as a broken wire, or as difficult as diagnosing multiple switches.
Let's see what happens here.
P
Old Oct 22, 2005 | 09:21 AM
mgerdes's Avatar
Default Re: 98 accord door lock-window switch problem-multiplex master window switch? (P_Adams)
understand completely, the keyless is the factory unit , not sure if that helps. i have checked every fuse in the car. had the drivers door panel off and checked the master window plug for connections and such. according to alldata there was a tsb on this problem and i figured a honda tech would have seen the problem, so they they could tell me where to start. alldata shows three multiplex control modules, the main drivers door switch plus two more under the dash. also their is a procedure to check all three, very long and drawn out. i wanted to avoid that.
my car has had the ignition switch recall, its amazing that after that was fixed my brake lights starting working again
Old Oct 23, 2005 | 03:23 AM
mgerdes's Avatar
its working again today, who can explain that?
Old Oct 23, 2005 | 05:49 AM
P_Adams's Avatar
Sometime Honda dispatches Elves from your local dealer in the still of the night, charged with the responcibility of effecting at least three unexplained repairs a night.
It works out pretty well except during the later part of the year, where they're temporarily reassigned to some guy at the North Pole.
You should be proud, they work off the same list
P
Old Oct 23, 2005 | 07:32 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgerdes &raquo;</TD></TR><TR><TD CLASS="quote">its working again today, who can explain that? </TD></TR></TABLE>
Did you have some rain and move your intermittent wiper switch? Sounds like your multiplex system got stuck in sleep mode, moving the intermittent wiper switch to one of the middle positions will usually wake them up.
Old Oct 23, 2005 | 07:44 AM
mgerdes's Avatar
Default Re: 98 accord door lock-window switch problem-multiplex master window switch? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Did you have some rain and move your intermittent wiper switch? </TD></TR></TABLE>
no rain here , high and dry. asked the wife and she said when she went to the grocery store they were not working and when she came out they were. oh well, we'll see for how long
Old Oct 23, 2005 | 05:48 PM
Accord_boy619's Avatar
My car does the same thing and I still aint fingered it out. Its bin doin it on n off for 3years now. Ive replaced the master prw window switch n it still does it.
Old Oct 23, 2005 | 06:18 PM
mgerdes's Avatar
Default Re: (Accord_boy619)
glad im not the only one maybe one of the techs has seen this happen and can enlighten us.
glad you told me about the master window switch, i was going to buy one
thanks, mark
Old Oct 23, 2005 | 06:25 PM
I gots 2 back @ home 3 total and all the same no luck. It acts up once n a while. Tho I got both of them on ebay, but couldnt be all 3 units bad. I just left it alone, hell its been like that for 3 years.
JAD
13
Oct 1, 2016 04:05 PM
H.N.F
May 18, 2016 07:42 AM
SoL_ger
Nov 23, 2014 09:47 AM
carve
Oct 6, 2009 02:44 PM
fcm
Nov 20, 2008 11:25 AM
