What size injectors for my turbo h23a motor?
Old Oct 20, 2005 | 10:45 AM
mnlude's Avatar
Default What size injectors for my turbo h23a motor?
I will be running 5-7lbs of boost on my h23a real soon and was wondering if any of you veterans have any suggestions on what size/type of injectors to put on my lude. Thanks.
Old Oct 20, 2005 | 11:42 AM
Under_Pressure's Avatar
Default Re: What size injectors for my turbo h23a motor? (mnlude)
550cc.
Old Oct 20, 2005 | 02:42 PM
prelittlelude's Avatar
you really need to think about the future of the project if -7 is it and will be for ever then 550s should be fine, but any more than 8 psi and those 550s are approching past optimuim duty cycle
Old Oct 20, 2005 | 05:49 PM
mnlude's Avatar
Default Re: What size injectors for my turbo h23a motor? (prelittlelude)
Some people that i've talked to said that if i'm only running around 5-7 lbs of boost I should just use my stock injectors. is this true? How will it affect my engine?
Old Oct 20, 2005 | 06:00 PM
Jeffrey9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mnlude &raquo;</TD></TR><TR><TD CLASS="quote">Some people that i've talked to said that if i'm only running around 5-7 lbs of boost I should just use my stock injectors. is this true? How will it affect my engine?</TD></TR></TABLE>
I've heard this as well. I'd like some info on the subject too.
Old Oct 21, 2005 | 04:59 AM
Default Re: What size injectors for my turbo h23a motor? (Jeffrey9)
what are u going to tune with.
Adam R.
Feb 19, 2013 07:38 PM
Luke G.
Jan 23, 2010 11:53 AM
matt_h22a
Jun 21, 2007 12:26 PM
digital sol
Jul 23, 2005 09:08 PM
jiten42
Jun 8, 2003 08:54 PM
