My Civic Died
Old Oct 20, 2005 | 10:40 AM
Chilly61383's Avatar
Default My Civic Died
Ok my civic took a turn for the worse. I recently blew my head gasket like 2 maybe 3 months ago and had everything replaced, all my belts : timing, AC, PS, Alt and changed the water pump and tensioner. Just recently it started dying on me, while driving it was smoking a lot out of the exhaust and when I hit the gas it felt like it didnt want to accelerate, its an auto by the way. Had it towed home. Did a leak test and there was no leakage. Right now it runs but it sounds like cylinder 1 or 2 isnt firing. My car sounds really crappy. I want to swap, but I'm on a low budget. Any ideas and is there anywhere in Southern California that does swaps for a good price?
Old Oct 20, 2005 | 10:43 AM
Firstoost's Avatar
Default Re: My Civic Died (Chilly61383)
does the exhaust tone kinda in any way sound like a WRX rumble? If so i had this exhaust tone and all my cylinders were mis-firing(douche-bag who didn't know wiring installed VAFC on GSR awhile back when i had it and the VAFC bad hook up fucked my whole motor over til i had it reinstalled professionally) so make sure all wires to your ECU are hooked up fine. then if that doesn't work i can't help further.
Old Oct 20, 2005 | 11:15 AM
marshun's Avatar
Default Re: My Civic Died (Firstoost)
when you replaced all that...did you have the heads redone? cause if you didnt i bet those valves arent sealing
compression test?
Old Oct 20, 2005 | 11:54 AM
Default Re: My Civic Died (marshun)
Head was milled with a 3 angle valve job.
Old Oct 20, 2005 | 11:55 AM
And yes the exhaust does sound a little like a WRX
Old Oct 20, 2005 | 11:56 AM
AbitAvenger's Avatar
R.I.P.
Old Oct 20, 2005 | 12:05 PM
ralphie14's Avatar
did they install the timing belt correctly? Maybe it is a few teeth off or something like that. It is worth a look. What color is the smoke that is comming out of the exhaust?
Old Oct 20, 2005 | 12:15 PM
Firstoost's Avatar
Default Re: My Civic Died (ralphie14)
I'm telling you to check your wiring first before you go into your engine bay
It's really easy...if all wires are in harness secured correctly than this isnt the problem, but check for a loose wire somewhere on your ECU harness. good luck
Old Oct 20, 2005 | 12:29 PM
93_cxEG's Avatar
hey bro don't listen to them wanabees import mechanic...from my own experience i had the same situation...i made a hard turn and blew my head and notice that white smoke was coming from my exhaust and my engine...thats when i notice that when i give it some gas it would kick in....so my advice to u is sell it or do a swap with a better engine and don't try to be a racer with an auto because its just lame....no offense auto. driver....
Old Oct 20, 2005 | 12:46 PM
censurebush's Avatar
From: everything for everyone, and nothing for ourselves
i'm sorry about the loss but i figure i should show support for a swap. spend a couple bucks for a used b16 or b18a1.
Old Oct 20, 2005 | 01:02 PM
Default Re: My Civic Died (censurebush)
I was thinking B16. There is a guy in Lake Forest (if you know where that is) that has a used B16 for $500, yeah too good to be true. He said the piston rings need to be replaced. By the way, how hard is it do to an Auto to Manual swap? And are there shops in Southern California able to do this? I asked Inlinefour and they told me $1000 alone for doing the swap, thats just labor
Old Oct 20, 2005 | 02:20 PM
Hatchbizzle00's Avatar
it definitely sounsa like a timing belt issue. Get a manual, It'll show you where to set the teeth at.
If that doesnt help, god will.
Old Oct 20, 2005 | 03:22 PM
marshun's Avatar
Default Re: (Hatchbizzle00)
maybe the dizzy is messed up from the head gasket blow?
Old Oct 20, 2005 | 03:28 PM
90civichb's Avatar
Default Re: My Civic Died (93_cxEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG &raquo;</TD></TR><TR><TD CLASS="quote">hey bro don't listen to them wanabees import mechanic...from my own experience i had the same situation...i made a hard turn and blew my head and notice that white smoke was coming from my exhaust and my engine...thats when i notice that when i give it some gas it would kick in....so my advice to u is sell it or do a swap with a better engine and don't try to be a racer with an auto because its just lame....no offense auto. driver....</TD></TR></TABLE>
Dude, your post wasn't informative at all. "them wannabees import mechanic" are giving good tips for what to look for.
There is no reason to get a swap that isn't affordable if his problem can be fixed with a little time and patience.
Good luck with it man
btw, is this a single cam or dual cam engine? I guess I missed it...
Old Oct 20, 2005 | 05:38 PM
Default Re: My Civic Died (90civichb)
Sadly its a single cam, its the OG D15B7. No the distributor is brand spanking new. So can anyone hook up an affordable swap. I'm thinkin B20
Old Oct 20, 2005 | 06:17 PM
Squallie's Avatar
in the same boat, happend 3 times. now saving for a b20 swap
Old Oct 20, 2005 | 08:16 PM
littleredcivic's Avatar
Default Re: My Civic Died (Squallie)
I have my old D15Z1 for sale... complete enough for you to install, it does burn some oil, by the time you need an oil change, the oil will be around the low dot on the dipstick. Its a stick of course, so you can convert your car... You will need to add a couple wires to make the wideband o2 and EGR work, I think I am missing a MAP, but you can use your old one. PM me if you are interested, the wideband o2 is almost brand new...like 15k miles, engine has about 145k. transmission is great.
Old Oct 20, 2005 | 09:18 PM
marshun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chilly61383 &raquo;</TD></TR><TR><TD CLASS="quote">Sadly its a single cam, its the OG D15B7. No the distributor is brand spanking new. So can anyone hook up an affordable swap. I'm thinkin B20</TD></TR></TABLE>
actually i needed a new dizzy when i did my h22 swap...and wouldntcha know it, the dizzy's ignitor just sucked! i replaced it with one i jacked from the junk yard and it started right up. but it didnt run well, replaced it with another dizzy (from where i bought the new one) and it ran fine.
Old Oct 20, 2005 | 09:30 PM
Default Re: My Civic Died (littleredcivic)
Thanks for the offer but I think I'm gonna go B-Series. I just need my car working where I can drive that **** to a shop or if someone can get me a good price on a B series and I'll do it myself.
Old Oct 21, 2005 | 12:50 PM
Bump for any more advice
Old Oct 24, 2005 | 03:47 AM
I got my **** running...GO ME! It was the headgasket again, the head bolts weren't torqued right( THANKS DAD!), u think u can trust an ASE certified mechanic, especially if hes your father. Thanks for the advice guys, but does anyone know where I can get an affordable O2 sensor, Honda has it for almost $300 its like 2 something. Autozone and Pepboys got it for like $75 anywhere else that might be cheaper?
Old Oct 24, 2005 | 06:29 AM
cheapest i found one for was 'bout $90
Old Oct 24, 2005 | 07:01 AM
siregcivic's Avatar
my car did that once where it sounded like a subie... pulled over and a fukin spark plug wire fell of the dizzy
Old Oct 24, 2005 | 11:15 AM
Default Re: (AlexanderTheGreat)
Why would I want a 14 sec car? I just need a point A to B car. Might get the new Si thats coming out. Or wait and see how the CRX thats hitting in 2007 is like. So thanks but no thanks on the not so helpful advice.
Old Oct 24, 2005 | 12:32 PM
Tony_EM1's Avatar
Default Re: (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger &raquo;</TD></TR><TR><TD CLASS="quote">R.I.P.</TD></TR></TABLE>
