Base fuel pressure and timing questions.
Old Oct 20, 2005 | 09:56 AM
underpressure02's Avatar
Default Base fuel pressure and timing questions.
I just picked up a hatch with a gsr swap in it. The bottom end is stock the head has a slight pp, skunk 2 stage 2 cams, sk2 cam gears, springs and retainers running stock gsr injectors with a kenji chipped ecu. Soon I am going to take the car down and get it dyno tuned but for now I wanted to know what do you guys normally run your base fuel pressure at and timing?
The reason I am asking is b/c the car started to run really rich and I saw the nut that locks the set screw in on the aem fpr was missing and I was running 55psi of fuel pressure. I backed it down to 45 but that still sounds high. I am only running 38psi on my turbo civic but have 756 injectors in that car.
Any help would be great.
Old Oct 20, 2005 | 05:36 PM
makelove2hondas's Avatar
Default Re: Base fuel pressure and timing questions. (underpressure02)
find out if it is running rich with that pressure of fuel and go from there
Old Oct 20, 2005 | 06:04 PM
DEMNTD1's Avatar
Default Re: Base fuel pressure and timing questions. (makelove2hondas)
Stock fuel pressure is about 47 to 48 psi with vacuum off and stock injectors 240cc.
But since you are running a rechipped ecu, it may be dumping more fuel.
I say get on a dyno or get a wideband for proper A/F readings.
Old Oct 21, 2005 | 05:44 AM
Default Re: Base fuel pressure and timing questions. (DEMNTD1)
I have a wideband in my turbo civic but it is a pain in the *** to uninstall. I guess I will have to do that.
poodlemuffer
Engine Management and Tuning
Feb 1, 2014 09:24 AM
Ruben19
Jan 29, 2006 04:31 PM
93preludeh22
Sep 23, 2003 03:38 PM
Mr. Softee
Mar 6, 2002 05:28 PM
