wich pistons rings to use?
I'm putting OEM jdm p30 pistons in my jdm b18b and I was wondering wich pistons rings to use and if oem rings are better then aftermarket????
Thanks!!
Parts that I have bought = p30 pistons and locks, crane Springs and retainers, crower 404 cams
taking my head off and sending it away to a machine shop first thing monday!!
Thanks!!
but do I use the b18b (my block) or the b16 (cause of the pistons) or does it not matter cause theay are both the same bore size???
OEM rings run around $100, many builders use the Hastings rings because they are high quality and run around $50 from there web site.
Nice parts you have for your build, I have the same parts except for PR3 pistons instead. I was wondering how you were going to tune this build? I was going to use a chipped P28 with a basemap taylored to these mods for a temp solution until I can get it dyno-tuned. How about you?
I'm definitly going to get it dyno and for now chip my obd1 P75 ecu!!!! But from what i have herd to really unleash the poer I would need to look into hondata or something along those line!!!
crome or neptune seems to be a worthy engine management..if you have a good tuner in your area...
my friend is using neptune making 202whp on a 1.8l b16...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PogKai »</TD></TR><TR><TD CLASS="quote">I use Nippon Piston Ring.. they supply rings to Honda so it's kind of OEM but cheaper. Works for me!</TD></TR></TABLE>
Ya, I have seen those on Ebay for $50 also, I just haven't seen too many builds using them or I would try them.
Thanks, I think I will saty away!!! I am lloking for after market rings cause I know a distributer and I get stuff under cost...oem stuff is expensive!!!
What are good after market rings???
