Braking = Shaking
hey, i noticed a while ago that when i hit the brakes the car shakes a bit. What is causing it to do this. is it the rotor. is there anyway i can tell if its the front or rear? i really cant afford to change both front and rear rotors now??????
U only need the front. Your rotors have to be cut (resurfaced). Depending on how much rotor material you have left you may or may not need to get new ones. If you need new breaks i would get them done at the same time.
rotors are warped.. you could opt to have them turned to make them tru/straight again.. but this takes off material.. so when it happened to me i just opted to get new rotors and pads (pads needed changing too on mine)..
i got my brembo blanks for $28 + shipping ($10).. at http://www.collettimotorsports.com.. but someone else found a better deal.. lemme go find that link and ill post it here..
edit: aight heres the link http://www.performancemotorcars.com $31.64/rotor..(you'll need 2) and shipping is free on orders over $50..
[Modified by GSRaCeRbOI, 12:01 AM 3/7/2002]
