Si transmission on a DX
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
I was thinking of getting an Si transmission for my 88 CRX DX for the close gears, will it bolt right on. Also will it make any or little difference in acceleration. Thanks guys
You will need an 88 trans unless you upgrade to a newer clutch like the 90-91. The 88's had a different number of splines than the newer ones.
It will give you better acceleration because of the different final drive.
One more question, which mod would give me the most performance in my D15B2, the si trans or change from DPFI to MPFI
the d15 will beat a si stock that is with the si tranny the stock sis ran 16s and if u do get a 90-91 clutch u need the flywheel from a 90-91 they are bigger
Canadian_EF
Nov 3, 2010 09:15 PM
Okay20
10
Jun 15, 2002 08:08 AM
