crower stage 2 h23
cant decied what cams to get for the h23, my valves are bent and i need to rebuild. Im gonna get aftermarket springs, valves and retainers. I plan on getting the crower stage 1 becuase i wont have to rev past stock redline to make most power. I was wondering if i got stage 2 and shift at the h23 redline(6500) would is till be making more power thne the stage 1s? on the crower website it says the stage 2 rpm range is up to 7800, the h23 bottom cant handle that speed.basicly is it worth getting stage 2 if i only plan on shiftin at 6500?
Modified by jdmaek at 5:40 AM 10/20/2005
There are not a lot of people out ther with H23 cams. Most take the easy way out and swap an H22 head. but there is some info out there.
https://honda-tech.com/zerothread?id=939641
https://honda-tech.com/zerothre...88109
https://honda-tech.com/zerothread?id=1105415
https://honda-tech.com/zerothread?id=1007198
Pirate
Pirate
The stage 2's are designed to give you more high end power, while stage 1's are meant for lower/mid power. If you don't plan on building up for high reving power, go with the stage 1's
AlexLude
Mar 13, 2004 10:34 AM
