Car Making Whining Noise
I have a 2000 Honda Accord SE and the car makes a whining noise whenever the heat or a/c is on. It also does it when the fan speeds are on 1-2-3-4. I also noticed that it makes the same noise when ever the defrost is used. I posted earlier to see if any one could help me with this, but I failed to mention the year and model.
I also had an air compressor put on but it isn't blowing very cool air. Does any one know what this could be? Miss Kita
Two questions I need answered so's I can help
1) Does this whine occure with both the A/C on/off ?
2) Is this noise more under the Hood, or on the right side of the dash.?
P
P
I drive a 2000 Honda Accord SE. This morning I couln't get my car to crank and I had to use a boost to get it started. I know the car was making a whining noise whenever I turned on the fan speeds for the airconditioner. Could this be the alternator or the battery? I did not have this problem until this morning. Could it be the alternator belt ? If some one knows or has suggestions please help?
If it cranked with a boost, and kept running when the cables were removed, you most likely have a bad battery.
The whining could be the Alternator working hard, trying to make something of the bogus Battery. The same could apply to when you asked it to work hard by turning on the A/C Fan etc. Althought that system can cause it's own whine as well....
You would do well to have both checked. The bad battery could well have damaged the alternator electrically.
P
I'd also check the trunk for your mother-in-law, they whine often and with the fold down seat they can get pretty loud
P
ashleymarie90
10
Sep 23, 2015 06:49 PM
ashleymarie90
Sep 22, 2015 08:42 AM
