Displaying wideband on narrowband gauge
Old Oct 19, 2005 | 07:35 PM
akira712's Avatar
Default Displaying wideband on narrowband gauge
will one of the analog outs from a innovate LC-1, when programed accordingly, display accurate afr on a narrowband gauge??
I understand that an (well autometer, and probally alot of others) A/F gauge has 20 segments corresponding from 20.0:1 to 10.0:1, so that would be a resolution of 0.5:1 afr.
Im not planing on using a narrowband gauge to be a tunning substitute but a semi accurate way to montor afr when not dataloging.
also would this be any different than using the plx wide-narrowband converter(with a plx wideband and narowband gauge).
really what i want to do is use the apexi TT afr option to monitor, and also with it i could use O2 voltage reading and have an even better resolution than 0.5:1.
Does anyone one do this that could comment?
Modified by akira712 at 8:55 AM 10/20/2005
Old Oct 19, 2005 | 07:56 PM
Tchleung's Avatar
PLX makes a wiadeband covnerting thing so it cahgnes the LED outputs on yuor narrowband autometer guage to represent diff values like a wideband. checkout their site.
Old Oct 19, 2005 | 10:55 PM
AspectIndustries's Avatar
Default Re: (Tchleung)
Any idea if the autometer afr gauge, can be possibly worked with any wideband?
For example, zeitronix, LM-1..etc...etc? Thanks.
Old Oct 20, 2005 | 04:39 AM
DaveF's Avatar
Default Re: (synik)
http://www.plxdevices.com/NB_WB_GaugeConv.htm
Old Oct 20, 2005 | 05:23 AM
PM-Performance's Avatar
with the PLX thing though you still need the wideband itself. This is just an add on so you can read on your Autometer gauge too from what I get of it
Old Oct 20, 2005 | 05:59 AM
Tchleung's Avatar
Default Re: (itr206)
That's correct, I forgot to mention that so not to confuse people
Old Oct 20, 2005 | 06:17 AM
DaveF's Avatar
i dont see a reason why this wouldnt work, as long as your outputs are on par with the plx wideband outputs??
Old Oct 20, 2005 | 06:28 AM
nfn15037's Avatar
Default Re: (Dturbocivic)
Yes the Innovate can be programmed with a narrowband output and as such will work with most any AF gauge.
Old Oct 20, 2005 | 07:52 AM
akira712's Avatar
Default Re: (nfn15037)
would u trust this method to monitor afr? not to tune with but just to monitor
Old Oct 20, 2005 | 08:32 AM
90SiRHatchTurbo's Avatar
So in theory could you buy the Bosch Wideband o2 sensor, the converter, and a narrowband A/F gauge to assemble a cheap Wideband AFR unit?
Old Oct 20, 2005 | 08:57 AM
akira712's Avatar
Default Re: (90SiRHatchTurbo)
no you need a wideband controller the wideband o2 sensor reading are not liner. the controller makes it liner, I think...
my idea is that the lc-1 can have its analog outs be programmed to display user defined Vdc and AFR, so use this "scaled down" afr to display on a narrowband gauge...in my case the apexi TT, dont know if it will be very accurate but i think ill try it and compare it to what i get from datalogging
http://www.innovatemotorsports...l.pdf
check out section 6
Old Oct 20, 2005 | 07:36 PM
scartail's Avatar
If your bold to try... You can make a led display by yourself... I found this link way back when... It looks pretty cool... http://members.tripod.com/~foz....html Though, I haven't tried the display yet.... I did try the digital tach as described in the link. And It works.
Old Oct 25, 2005 | 01:47 PM
akira712's Avatar
Well im gonna try the apexi TT with the lc-1, ill post how it works out...
JDM_EK4_Coupe
Jun 19, 2007 03:49 PM
Dizzum
May 1, 2006 08:08 PM
Loco Honkey
Nov 10, 2002 10:40 PM
Hybrid
Feb 14, 2002 10:30 AM
One8Hatch
Nov 30, 2001 05:10 PM
