B18a/b crank pulley
Old Oct 19, 2005 | 07:29 PM
SOHCD16y8's Avatar
Default B18a/b crank pulley
Im building a motor for a friend who has a 94 civic. The power steering pump has the rib belt design but his b18a has the v-belts style. I have an extra b18b crank pulley laying around that has the grooved belt style for the p/s. Would the pulley be ok to use. I really want it all to be in perfect balance still. Or should I just rig up a pulley for the p/s and reuse the b18a pulley to assure balance?
Old Oct 19, 2005 | 07:34 PM
ham's Avatar
ham
Default Re: B18a/b crank pulley (SOHCD16y8)
as long as its an oem pulley and the belts line up it will be ok. honda motors are 0 balanced and only need the rubber dampner in the pulley(cept itr/ctr), so you cant use a cheap aftermarket one or a ctr/itr. little vibrations are absorbed into the rubber instead of vibrating your lower end.
Old Oct 19, 2005 | 07:37 PM
SOHCD16y8's Avatar
so basically is wont make a difference because all crank pulleys or just slapped on at the factory and not balanced to the crank?
Old Oct 19, 2005 | 07:41 PM
ham's Avatar
ham
Default Re: (SOHCD16y8)
all the pulleys are balanced to zero so its like having nothing on the crank, but with vibration dampening.
but no, it wont make a difference.
Old Oct 19, 2005 | 07:49 PM
SOHCD16y8's Avatar
alright, thats pretty much what I though but just wanted a second opinion. Thanks
smokinloc
Mar 4, 2011 09:05 AM
miguel329
May 2, 2010 10:09 PM
bow tie
Oct 17, 2008 01:18 PM
wdyno
Mar 3, 2002 01:47 AM
