engine check light and gas problem
Old Oct 19, 2005 | 07:14 PM
LilKrnThugBoi253's Avatar
Default engine check light and gas problem
i have a 92 civic hatchback dx. my engine check light won't turn off. i disconnected the battery to reset my ecu and i disconnected the ecu and still didn't work. i need help on that and another thing is my hatch runs rich. all i have is intake. i can see my gas needle just droppin. i need help fixin that. thanks
Old Oct 19, 2005 | 07:22 PM
Alex_SiR's Avatar
Default Re: engine check light and gas problem (LilKrnThugBoi253)
Your probably have trouble with a oxygen sensor , check the one that goes on the intake, and the one on the header, those are the ones that go the fastest
Old Oct 19, 2005 | 07:43 PM
Auex's Avatar
Have you tried pulling the code to see what is going on?
Old Oct 19, 2005 | 07:49 PM
coquitlamEG's Avatar
Default Re: engine check light and gas problem (Auex)
Somewhere around your ecu behind the passenger side kick panel is a two prong connector that isn't attached to anything. Should be a blue connector if i remember right. Anyways, you have to use a piece of wire or something to jump the two prongs in the connector together. Turn your ignition to on and then your cel will start to flash a code. for example; If it flashes like this
Flash...flash pause flash...flash...flash That would be code 23
2 flashes pause 3flashes
Let us know what you find. (PS sorry if you already knew all that)
Old Oct 19, 2005 | 08:13 PM
thanks for all ur guy's help i'll get it check up tomorrow and tell u about it
Old Oct 19, 2005 | 08:54 PM
.Ry's Avatar
.Ry
Default Re: (LilKrnThugBoi253)
Is the plug really not attached to anything? Ive searched high and low for a pic of it on my ej8 and no luck.
Old Oct 20, 2005 | 09:53 PM
when i went to go check the engine code thing. i realized i had a vtec ecu, so traded one of my buddies for his non vtec ecu and now my engine lite turned off. thanks for all ur guys help
ph0shizzle
May 13, 2006 08:36 PM
uglyduckling
May 5, 2005 08:01 PM
BigMig
May 10, 2003 06:01 PM
SuPeRITR
Mar 18, 2003 06:02 PM
civicracer1993
Apr 18, 2002 06:57 PM
