engine check light and gas problem
i have a 92 civic hatchback dx. my engine check light won't turn off. i disconnected the battery to reset my ecu and i disconnected the ecu and still didn't work. i need help on that and another thing is my hatch runs rich. all i have is intake. i can see my gas needle just droppin. i need help fixin that. thanks
Re: engine check light and gas problem (LilKrnThugBoi253)
Your probably have trouble with a oxygen sensor , check the one that goes on the intake, and the one on the header, those are the ones that go the fastest
Re: engine check light and gas problem (Auex)
Somewhere around your ecu behind the passenger side kick panel is a two prong connector that isn't attached to anything. Should be a blue connector if i remember right. Anyways, you have to use a piece of wire or something to jump the two prongs in the connector together. Turn your ignition to on and then your cel will start to flash a code. for example; If it flashes like this
Flash...flash pause flash...flash...flash That would be code 23
2 flashes pause 3flashes
Let us know what you find. (PS sorry if you already knew all that)
Re: (LilKrnThugBoi253)
Is the plug really not attached to anything? Ive searched high and low for a pic of it on my ej8 and no luck.
when i went to go check the engine code thing. i realized i had a vtec ecu, so traded one of my buddies for his non vtec ecu and now my engine lite turned off. thanks for all ur guys help
ph0shizzle
05-13-2006 08:36 PM
BigMig
05-10-2003 06:01 PM
hmm? my check engine light sometimes comes on and when i press the gas it waits like 2 seconds b 4 i
civicracer1993
04-18-2002 06:57 PM
