Suspension & Brakes Theory, alignment, spring rates....
Ban the word "pre-load"
Old Oct 19, 2005 | 06:28 PM
shortyz21's Avatar
Default Ban the word "pre-load"
ok this is a slight venting post. im sick of people posting about omnipower crap and "preload"
every topic with bad ride 50 people say "PRELOAD THEM"
back in the day i had HR lowering springs and those were a good 2" from being preloaded on the shock. not once did they ever come out of the seat.
personally i think preloading is a myth because the weight of the car holds the spring tight even at like 50lbs pressure. now unless your hitting jumps and getting your car airborn the springs arent going to slack..
chime in with your opinions
or your hitting speed bumps at 40mph...
Old Oct 19, 2005 | 09:00 PM
artifex's Avatar
say it
Default Re: Ban the word "pre-load" (shortyz21)
we should also ban any topic with the word 'best' in it from this forum.
Old Oct 19, 2005 | 09:50 PM
EK k kay's Avatar
Default Re: Ban the word "pre-load" (artifex)
If an online message board pisses you off this much that you have to post about it you need to get out of the house.
Old Oct 20, 2005 | 03:18 AM
KOALA YUMMIES's Avatar
Default Re: Ban the word "pre-load" (EK k kay)
Theres a great longass thread in the RR/Auto-x forum about preload.
Anyone that tells you that preload affect spring rate... dont listen to them.
Old Oct 20, 2005 | 05:33 AM
AutoXer's Avatar
Default Re: Ban the word "pre-load" (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">
Anyone that tells you that preload affect spring rate... dont listen to them. </TD></TR></TABLE>
True for linear rate springs. If the springs were progressive, wouldn't it change the rate, due to the fact that as a progressive spring is compressed the rate increases?
Old Oct 20, 2005 | 07:05 AM
GoldBadge's Avatar
Actully, as far as I know, the original use for preloading a spring is to stiffen or soften it in oder to optimize the performance of your suspension.
I can preload my omnis so that the springs alreaday carry a given load before they even begin to be comrpessed by the car and then an even greater load once you take a corner.
As for the entire debate about your spring leaving the seat, I completely agree with you. Unless your suspension is miraculously extending to its maximum (as if it were on jack stands) then your springs will stay "loaded".
And anybody that is dumb enough to own a set of height adjustable coilovers (I'm not referring to shortyz21 here) and install them with enough play for the spring to move an inch shouldn't have them in the first place.
Old Oct 20, 2005 | 07:47 AM
Solracer's Avatar
Default Re: (GoldBadge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldBadge &raquo;</TD></TR><TR><TD CLASS="quote">Actully, as far as I know, the original use for preloading a spring is to stiffen or soften it in oder to optimize the performance of your suspension.
I can preload my omnis so that the springs alreaday carry a given load before they even begin to be comrpessed by the car and then an even greater load once you take a corner.</TD></TR></TABLE>
Yep, you really don't know much then....
Old Oct 20, 2005 | 07:49 AM
AutoXer's Avatar
I think you may be confusing load with springrate. Your suspension is loaded more while cornering, but that doesn't effect the springrate or how much that load compresses the spring (if they're non-progressive).
Rahjahdat
Honda S2000
Jan 10, 2007 07:58 PM
GoLowDrew
Suspension & Brakes
May 18, 2006 06:41 PM
Quik89Si
Jul 22, 2003 11:03 PM
UdontknowME
Jun 29, 2003 02:48 PM
