clutch slipping eratically
Old Oct 19, 2005 | 05:31 PM
herde1724's Avatar
Default clutch slipping eratically
ok so today i'm driving home from school just driving normal shifting at like 4 grand shift to 2nd and put my foot back on the gas and the clutch slips.......so i just drive it home normal continues to slip if i floor it 2nd gear 25mph slips badly so i'm like expletive right gotta switch the clutch out go to work leave work expecting it to be slipping still and no matter what i do clutch will not slip i try beatin on it 1st 2nd nothin grabs fine i'm at a loss
completely stock ls integra 115k on the motor
Old Oct 20, 2005 | 01:02 AM
Cuda70's Avatar
Default Re: clutch slipping eratically (herde1724)
Hmm, I had a similar problem and finally deduced that it was spring bind in the clutch master cylinder (All I could figure). I removed the push rod from the clutch pedal assembly and kind of jostled the cup of the master cylinder around a little. It started feeling a little smoother so I put the pin back in and so far (5 days now) everything is fine.
My clutch has less than 1k miles on it with a new PP, release bearing, and surfaced flywheel. So I figured that something was wrong with the hydraulic system. I cant find any leakage in the system, so it had to be a mechanical part. That's what I finally came up with, but we shall see if I was wrong or not.. heh!
Mikeyb918
Oct 31, 2012 05:55 PM
komat
Aug 6, 2010 12:04 PM
Z7
11
Feb 9, 2006 06:53 PM
JDM Jimmy
Feb 25, 2004 01:26 PM
