Skunk manifold
Old Mar 6, 2002 | 01:15 PM
whttyper1998's Avatar
New User
Default Skunk manifold
I'm going to help my best friend install the skunk manifold on his gsr. He has type R cams and i/h/e. Did anyone get the check engine light (CEL) after they installed the skunk manifold?
Thanks
Old Mar 7, 2002 | 07:40 AM
JumbosGS-R's Avatar
New User
Default Re: Skunk manifold (whttyper1998)
my buddy just did it to his and had no problems....but then again he has a new computer. As long as you have all the vac hoses on right and sensors in the right spots you'll be fine.
Old Mar 7, 2002 | 08:50 AM
TRuST's Avatar
The CEL I got was a Evap canistor, to fix all I had to do is T it off another Vacuum hose and that fix the problem.
Old Mar 7, 2002 | 05:57 PM
JdoggsGSR's Avatar
New User
Default Re: Skunk manifold (TRuST)
Yeah thats the same CEL code i threw yesterday and i ran it off the other hoses..
Old Mar 7, 2002 | 07:07 PM
alexboy's Avatar
Default Re: Skunk manifold (JdoggsGSR)
If correctly iinstalled no check engine codes should be thrown however if not properly sealed between manifold and throttle body you can through a code
BlkChryKord
May 9, 2005 04:35 PM
jeffchaisi
Mar 23, 2005 10:28 PM
AVXHATCH
Oct 28, 2003 05:15 PM
ef-sihatch
Oct 27, 2003 09:00 AM
