energy suspension motor mounts
i just recieved my kit for the lower M.M on my g3 teg. there is the 2 in the kit for the 2 front lower mounts(tranny and belt side) and then there is a 3rd one. it says the 3rd one is a rear mount...i ran out of daylight, and i just couldnt see where it was. is this one commonly replaced or is it not necessary? i seen an article on team integra and it mentioned how to replace the front 2 but didnt mention the rear one.
if your engine compartment is stock... your going to have a hard time chainging the back mount.
if its clean and has gone through motor swap(usually people take out unnessary things)it will be much easier.
**you can still change it even if everything is still there, just takes alot of time.
It sits way back up inbetween the bottom of the firewall and the subframe. You need to remove the rear bracket to get at it, and it's a bitch if the motor is in the car at all, stock or otherwise.
SCCAsean
Aug 30, 2005 12:13 PM
Drew Peacock
Dec 3, 2004 03:31 PM
