Full swap or not, I'm just about ready to pull the trigger.
Old Oct 19, 2005 | 12:11 PM
noboostedEGo's Avatar
Default Full swap or not, I'm just about ready to pull the trigger.
Hey guys, I'm hoping this is the right forum for this q. Anyway, I'm lookin' to get a full gsr swap off of hmotorsonline. It's a little pricey but they have such a good rep so that should be worth some assurance. Anyway, the full swap is $500 more than just the motor, tranny, and ecu. The only additonal items listed are stock motor mounts, shift linkage, and axles. Are these three extra items worth $500? What I wanna know is if I should just go ahead and get it or if I should just get motor, tranny, ecu and scrounge together the other stuff. I just wanna do it right. Sorry that was long, but thanks a bunch. Btw, it'd be going in a 93 dx hatch (d15b7 power )
Old Oct 19, 2005 | 12:16 PM
ExplicitSpeed360's Avatar
Banned.
Default Re: Full swap or not, I'm just about ready to pull the trigger. (noboostedEGo)
I am not a eg owner but my guess I think you can use the motor mounts and shift linkage and axles. But I would recommend not paying the extra and just get new stuff new axles from schucks $60 a piece, integra shift linkage from junkyard may need to be mod? $20 and some namebrand motor mounts or no name but good quality off ebay for $140
Old Oct 19, 2005 | 12:19 PM
Default Re: Full swap or not, I'm just about ready to pull the trigger. (ExplicitSpeed360)
I'm pretty sure the swap requires a combination of stock mounts and integra mounts. There are diagrams floating around for it. That's a good idea though, I'm leaning a little more towards motor, tranny, ecu. Thanks so much for the quick response, I appreciate it! Keep it coming, I may order today or very soon!
Old Oct 20, 2005 | 06:14 AM
Jwbetley's Avatar
many places are different. some places will sell you the engine/tranny, but give you the shaft on the rear bracket, half shaft, and even side mount brackets. others will give it all to you. I would probably just invest the extra $500 if i were in your shoes. Linkage is $135 (youll get the shifter if your lucky) , mounts are about $120, and shafts are about $120, thats $365 with out peice of mind of getting everything you need.
Old Oct 20, 2005 | 12:39 PM
Default Re: Full swap or not, I'm just about ready to pull the trigger. (Jwbetley)
A very valid point. Thanks.
nk2k2
Feb 9, 2006 04:27 PM
240sxDrift
Aug 3, 2005 07:55 AM
LS REX
Jul 23, 2004 07:21 PM
Vintech
Apr 16, 2004 12:38 AM
Jinya1004
May 6, 2003 09:51 AM
