Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
driver cooling in a HC car?
Old Oct 19, 2005 | 07:04 AM
577HondaPrelude's Avatar
Default driver cooling in a HC car?
I asked this question a few days ago on the NASA sight and didn't get any info, so I'm going to try here also
I would really like to install some driver cooling air ducts in my car. However the rules state (H2) that all body panels must remain OEM. Thus I can't cut any holes. They also state that I can't use lexan for any of the windows, even the little triangle rear side ones. Most cars use these little windows to install driver cooling ducts and this is illegal in HC as far as I can tell. What is the best way to get air ducts to the driver and still be legal for HC?
Old Oct 19, 2005 | 07:08 AM
Crazydave's Avatar
Default Re: driver cooling in a HC car? (577HondaPrelude)
From the Honda Challenge Rule Book:
7.11.L:
Ducting may be installed to provide fresh air to the driver’s compartment. Ducts may be installed in
the driver or passenger window area. A “fresh air system” which supplies air to the driver only is also
permitted.
7.11.M:
Driver cooling (such as cool suit) systems may be used.
Old Oct 19, 2005 | 07:29 AM
Track rat's Avatar
Default Re: driver cooling in a HC car? (Crazydave)
I read "7:11 L" as permitting a duct mounted securely in a small piece of lexan near the side view mirror area of the driver or passenger window as acceptable. That's what I did.
As a quick fix, you can lay an air duct hose facing forward out of the driver's window and cable tie it in place.
Old Oct 19, 2005 | 07:45 AM
117's Avatar
117
A Texas H3 car here uses a lexal duct installed in the upper rear corner of the driver's window going to a cool suit type setup. It works fine, and is perfectly legal. Not the prettiest way to do it, but it's functional.
Old Oct 19, 2005 | 07:54 AM
prkiller's Avatar
Default Re: (117)
You also have to look at the track you will visit and factor that in. Being that you are on the east coast, you probably wont run into the same problem we have here on the west coast. You have nice pretty tracks, where as we have lots of dirt!
I have wanted to install something for cooling as well, but it just does not make sense for me. We race at Willow, Buttonwillow, and even at Infineon and Laguna you will get a face full of dirt if someone puts 2 wheels off in front of you. That is the reason I have not installed some sort of cooling air yet?
Old Oct 19, 2005 | 10:10 PM
Outrun's Avatar
Default Re: (prkiller)
"ENDLESS 9" had this back in July 04 at Willow Springs.
Old Oct 19, 2005 | 10:22 PM
TeamSlowdotOrg's Avatar
They make them with sweet chrome k&n filters on them you know.
Old Oct 20, 2005 | 12:48 AM
slammed_93_hatch's Avatar
Default Re: (TeamSlowdotOrg)
you could try something like this
http://fotoproduction.com/IMG_4022.jpg
the picture that outrun has, also works. Only problem we have had with it is the driver said that stuff was flying and hitting his helmet
ACardAttack
Honda CR-V & Element
Oct 15, 2016 06:57 AM
E dwinbon G
24
Mar 2, 2004 12:13 AM
Asterix
Jul 22, 2002 02:57 PM
