RPM needle bouncing question.....
Old Oct 19, 2005 | 05:58 AM
SlowSOHC-T's Avatar
Default RPM needle bouncing question.....
Here's the situation, my car had a fouled out plug wire for about a week. While the car was missing, it made my RPM's bounce...EXAMPLE: If i had cruise control on at 65mph, the rpm gauge would be around 3k....With out speeding up or slowing down, the rpm needle would bounce up from 3k all teh way to 6k and than go back down. Now that i have replaced the plugs and wires, the car is no longer missing, and its still doing it. What could it be? Is it still reading a misfire somewhere, such as in the distributor cap?
Any help, suggestions, comments, concerns would be greatly appreciated.
Thanks
Old Oct 19, 2005 | 07:01 AM
SlowSOHC-T's Avatar
Default Re: RPM needle bouncing question..... (IWANTAHB)
10 people have looked at this and no one has any idea?
Old Oct 19, 2005 | 08:35 AM
95lstegman's Avatar
it seems to me it should have something to do with one of the sensors inside the distributor, like crankshaft position sensor. i'm rather sure it's a problem in the distributor though. what's the year/make/model? later cars have the CYP sensor in the oil pump housing.
Old Oct 19, 2005 | 08:39 AM
SlowSOHC-T's Avatar
its a 94 LS integra
Old Oct 19, 2005 | 10:36 AM
95lstegman's Avatar
Default Re: (IWANTAHB)
then yes, CYP sensor is inside the distributor. i seem to remember it having something to do with the distributor, although the CYP sensor is very difficult to get to. it's buried in there.
Old Oct 19, 2005 | 10:55 AM
SlowSOHC-T's Avatar
Default Re: (95lstegman)
so what do you suggest? A new distributor? or a new sensor? It seems that if i hammer down on my car in HIGH RPMS the car still wants to miss alittle bit. My passengers can't tell, but i can just barely fill it missing....
So new Distributor? Yay or Nay
Old Oct 19, 2005 | 11:29 AM
gsrobdi's Avatar
the same thing happend to my car. i changed my dizzy and it was all good. but if oyu want, try cleaning the rpm signal wire thats goes to the dizzy.
Old Oct 19, 2005 | 11:40 AM
LowTEC SaiMike's Avatar
Default Re: (gsrobdi)
my friend actually has had his RPM drop and doesn't work , found out a wire got loose on the dizzy and we just hooked it back up agian and it works
Old Oct 19, 2005 | 12:00 PM
DeDonDeRosa's Avatar
Default Re: (BomBoi)
SOUNDS TO ME LIKE YOUR IGNITOR happend to me in my crx and my 1 honda mech told me that was it no doubt about it the tach would jump like crazy
NUMBER 8!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 19, 2005 | 01:16 PM
SlowSOHC-T's Avatar
Mines not really jumping like crazy, its just sparaticly happening. Im going to try and clean the connection today and see if that fixes it. If not i guess im going to get a new dizzy
Old Oct 19, 2005 | 02:02 PM
95lstegman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">SOUNDS TO ME LIKE YOUR IGNITOR happend to me in my crx and my 1 honda mech told me that was it no doubt about it the tach would jump like crazy</TD></TR></TABLE>
yeah, now that you mention it that sounds pretty familiar. i remember having a REALLY weird problem with my dizzy, and i kept seeing "hey, my tach needle keeps jumping around" and thinking "dang, when will i ever find somebody with the same problem as mine?". i was searching h-t and found like a hundred questions just like this one . . .
Old Oct 19, 2005 | 03:34 PM
DO NOT REPLACE YOUR WHOLE DIST. CAUSE WHATS HAPPENEING TO YOU HAPPENED TO ME THE SAME WAY IT WILL JUST GET WORSE MY STARTED DOING IT VERY LITTLE THEN STARTED GOIN NUTS THEN AFTER AWHILE YOU WILL HAVE PROBS WITH THE CAR DIEIGN WHILE DRIVING
REPLACE THE IGNITOR 1ST!!!!!!!!!!!!!!!!!! ITS ONLY 80 BUCKS
Old Oct 21, 2005 | 06:17 AM
SlowSOHC-T's Avatar
Well today it seemed like it was getting worse, and my RPM needle started bouncing all the way to Redline today while sitting at a light. It also seems that the car is starting to miss again at higher rpms (5k or so), i was passing a truck today and it started either missing or spinning bc it was raining....
I'm getting a dist. to try for a few days and if that don't fix it Im going to buy a new ignitor..
Old Oct 21, 2005 | 07:15 AM
kulrevon's Avatar
well the ignitor is in the dizzy so if you replace the dizzy it would be like fixing the ignitor and more. unless the other ignitor was bad.
I would say ignitor too.
Or if you can get a dizzy for cheap do it. and save the parts.
Old Oct 21, 2005 | 07:45 AM
projectTeG's Avatar
also check to see if you have any disconnect or fuxor'd grounds. BTW a good way to tell if the ignitor is busted is test it with a mulitmeter.
Modified by projectTeG at 5:26 PM 10/21/2005
Old Oct 21, 2005 | 08:05 AM
Default Re: (projectTeG)
dont go out and waste your money on a whole dist . go out and buy the ignitor try that 1st will save u a lot of time and money cause the igniotor is in the dist so fix it the easy way
Old Oct 27, 2005 | 08:12 AM
SlowSOHC-T's Avatar
ok, so i haven't been able to get around to fixing my car but i have a story and a question. First:
So im driving today and im watching my RPMs and while im doing 70mph the needle falls all the way to 0....than hic ups/misses and back up to 3k rpms.....Than it did it again when i got off the express way, but this time it shut the car off. Now is this caused from the same issue or different issues?
Also how bad of gas mileage did you guys get when having this problem? I filled up yesterday and usually by 3/4 of a tank i have about 120miles on the tank, this week i had like 64miles or so...........Im going to swap out the ignitor today...Just wanted some feedback..
Old Oct 27, 2005 | 10:33 AM
SlowSOHC-T's Avatar
Come on somebody has to help me out.......
Old Oct 27, 2005 | 11:28 AM
kulrevon's Avatar
what dont you understand about check your ignitor. or fix your ignitor.
people ask for help then dont take the advice.
I am going to say it one more time test your ignitor.
Old Oct 27, 2005 | 01:02 PM
SlowSOHC-T's Avatar
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">what dont you understand about check your ignitor. or fix your ignitor.
I am going to say it one more time test your ignitor.</TD></TR></TABLE>
Like i previously said i haven't gotten around to fixing it. I have been beyone busy and the guy who is getting me a new distributor for cheap hasn't gotten it yet. But now since my car just won't start at all im going to get a new one ignitior today and see if it fixes it. IF so yippie, if not i guess im going to buy a new distributor..
But my main question was, did this cause anyone to have bad gas mileage? I mean real bad? Im just trying to see if there is another issue i need to look into....
Old Oct 27, 2005 | 02:59 PM
whiteef8's Avatar
what me and my buddy did to his teg was took off the dizzy cap, put some di-electric grease on all the connections, and put the cap back on. after that, no more bouncing tach... my .02
good luck
Old Oct 27, 2005 | 11:04 PM
watsvtecEK's Avatar
Default Re: (whiteef8)
ya, i had the same problem about a week ago, follow these directions.. if this dose not help you need a new ignitor, this worked for me..
http://www.g2ic.com/tegtips/engine/10.html
and also look at that diagram on the top of the thread, it is kind of hard to see the ignitor, but there are 4 wires going to it and it is kind of on the bottom of he distributer. good luck
Old Oct 27, 2005 | 11:05 PM
watsvtecEK's Avatar
Default Re: (b18tegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteef8 &raquo;</TD></TR><TR><TD CLASS="quote">what me and my buddy did to his teg was took off the dizzy cap, put some di-electric grease on all the connections, and put the cap back on. after that, no more bouncing tach... my .02
good luck </TD></TR></TABLE>
yepp.....
Old Oct 29, 2005 | 07:01 PM
91IntegraX's Avatar
its happenin to me now too bounce bounce all the time...and i seem to be getting shitty *** mileage too
Yuta
Oct 14, 2018 06:03 PM
andyandrew2006
Feb 5, 2013 12:56 PM
tommygunn
Jul 14, 2010 04:53 AM
enot767
Oct 10, 2008 01:18 PM
alexsracing
Nov 20, 2007 10:17 AM
