hey guys
Old Oct 18, 2005 | 11:00 PM
standaloneaccord's Avatar
Default hey guys
hey guys i drive a 90 accord and i want to make it in to a font and back disk brakes how would i be able to do it?
Old Oct 18, 2005 | 11:13 PM
momstaxi's Avatar
Default Re: hey guys (standaloneaccord)
unbolt rear drum brake assembly, then bolt on rear disc assembly. its pretty easy, i find it easiest to just get the whole reardisc/knuckle and trailing arm as one piece and put it on like that. you will also need to hook up ebrake cables from the discs to the handle. bleed brake system...
if you search, there is a ton of info covered on this topic...
Old Oct 19, 2005 | 06:11 AM
fw190bvi's Avatar
Default Re: hey guys (momstaxi)
go to a junk yard...get the trailing arms, nuckle, etc from a junk yard from either a rear disk equipped 4th gen (EX and 93 SE?) or from a 94-97 EX
Old Oct 19, 2005 | 04:47 PM
thanks guys. isnt it ture that the 93 ex is all wheel disc? because if it is ill just go and get that and do it like that
Old Oct 19, 2005 | 05:18 PM
BLKFLSH's Avatar
Default Re: (standaloneaccord)
I'm pretty sure all ex's have 4 wheel disc brakes.
mickyT
Sep 19, 2007 11:28 AM
syclone
Feb 15, 2005 05:39 AM
footmans
Aug 25, 2004 11:52 AM
HANABLE
Apr 8, 2004 11:08 AM
abraunworth
Mar 30, 2002 04:11 PM
