oxygen (air/fuel) sensor/DC Headers *NEED HELP*
Old Oct 18, 2005 | 08:09 PM
untitleJk's Avatar
Default oxygen (air/fuel) sensor/DC Headers *NEED HELP*
Hi, I'm having a problem with my DC 421 ceramic headers and thought somebody might have a solution.
I own a '02 Accord 4cyl (F23A4 ULEV) and I installed the 421 DC Sports Ceramic Headers.
When I installed them, I made sure I disconnected the battery but afterwards the Check Engine Light came on. I checked the wiring and noticed that the headers melted the oxygen (air/fuel) sensor straight through. So I used 22-gauge "connecting wire" from Radio Shack and re-wired them. They seem to be fine but maybe after 2 hours of driving, the CEL comes back on.
I did the CEL code hot-wiring and got the code 61, which is "Primary Heated Oxygen Sensor (Primary Ho2S) (Sensor 1) Slow Response". Then I decided to try running the car without the oxygen (air/fuel) sensor.. then I started getting code 45, which is "Fuel System Too Lean" or "Fuel System Too Rich".
Here is a picture of my sensor and plugs..
I want to avoid buying a $200+ replacement sensor for my car, so if anyone has any solutions, PLEASE HELP. Thanks in advance.
Old Oct 19, 2005 | 10:51 AM
untitleJk's Avatar
^ bump.. I need help guys
Old Oct 19, 2005 | 06:28 PM
Jago's Avatar
Default Re: (untitleJk)
you need to buy a new o2 sensor
Old Oct 20, 2005 | 04:25 AM
SOHFAST94's Avatar
Default Re: (Jago)
You could buy some male/female connectors from your local auto parts store and then BAM it's done.
kalanikaau
Honda CR-V & Element
Apr 23, 2019 07:25 PM
bernardo1989
10
Feb 7, 2009 03:56 PM
vtec25
May 15, 2006 02:07 AM
K20A2TypeR
Feb 13, 2006 04:29 AM
maxspeedhonda
Jul 3, 2005 05:04 AM
