Lack of info on the type s piston is really pissing me off...
https://honda-tech.com/zerothread?id=1232811
has almost everything you need for compression calculations....when you dont know the compression...so flyrod's page wont help here....
basically i am trying to gain the info of
ccs for each piston
usdm h22 -
jdm h22 -
type s h22 -
and compression height on the type s...
i have been trying to calculate compression for a f23 hybrid/type s pistons....for myself....i dont trust the estimates....nor do i trust pump gas....
thanks gentlemen.....and yes this is also posted in the prelude forum....
ccs for each piston
usdm h22 -
jdm h22 -
type s h22 -
compression height is the same as every other h22...
if you know the bore, the stroke and combustion chamber cc's and compression of a normal h22 then you can play w/numbers till you come up with 11:1 for the type s stuff
i mean who really cares about h22's anyways??
j/k
edit: sorry i just remembered i already think i messed with u about h22's before. Sorry.. good luck!
j/kedit: sorry i just remembered i already think i messed with u about h22's before. Sorry.. good luck!
h224thgensedan
Apr 24, 2008 12:11 PM
mgags7
Oct 21, 2005 02:29 PM
