Gsr Cluster Problem
as ya kno i did my swap just got my cluster in from a 95 gsr. Everything is pluged in perfect and i start the car and the rpm shoots up to 5k and speedometer to 20mph. Also my gas is a little off, but not that big of a deal (i never let it go too low that i have to worry) Any input on how to fix the needles? The jump when i rev the car and drive. So its just the placement that is off. I tried searching with no definite results. Thanks
Often, cluster maladies can be solved by using the film from the original cluster on the new one. Being that it came out of a 95 and your car is a 95 there should be no issues, but there's always that odd possibility.
Do they ever fail to function? i.e. does your speedo ever drop to zero while driving? If so your speed sensor may be dirty, happened to me with my del sol. Give that a cleaning and see if it clears anything up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 »</TD></TR><TR><TD CLASS="quote">Do they ever fail to function? i.e. does your speedo ever drop to zero while driving? If so your speed sensor may be dirty, happened to me with my del sol. Give that a cleaning and see if it clears anything up.</TD></TR></TABLE>
nah they dont fail they stay up there. Only thing is they dont drop unless i turn the car off. They stay at the 5k and 20mph when im idle
hey any help.. i got the temp, rpm, and speedometer working. Now the only thing is the gas it goes all the way up high then when im driving it drops low and the low fuel sign comes on.. I just filled my tank all the way so I know my tank is full. How can i get this to stop jumping?
andrew dc
Apr 29, 2003 07:11 AM
