Hondata IM Gasket/Euro-R
Old Oct 18, 2005 | 04:27 PM
snowblind7x's Avatar
Default Hondata IM Gasket/Euro-R
When using the hondata intake manifold gasket with a Euro-R IM (I have the complete Euro-R engine swap, not just IM) does it fit correctly?
Old Oct 18, 2005 | 07:23 PM
Default Re: Hondata IM Gasket/Euro-R (snowblind7x)
bump
Old Oct 18, 2005 | 07:58 PM
mgags7's Avatar
i doubt it will be exact around the injectors...but doing a little dremel work shouldnt be too hard...
Old Oct 18, 2005 | 09:46 PM
Power Rev Racing's Avatar
Default Re: (mgags7)
It fits fine. Thats what I have in my car. But then again. I hit the manifold and the gasket with the dremel tool. Because the injectors did not slide into the manifold or something. I dont remember exactly that was like a year ago But its easy to tell, just line up the gasket next to the intake manifold and put in injectors
Old Oct 19, 2005 | 04:33 AM
Honda318dx's Avatar
Default Re: (Power Rev Racing)
The proper injectors to use are the long tipped Euro-R ones, or S2k ones.. I used RC440s which don't protrude as far as I liked into the mainfold, so I shaved down the little tips a little bit at the injector ports..
But yes, I use the hondata gasket with that manifold and everything fits fine..
Old Oct 19, 2005 | 07:44 AM
Default Re: (Honda318dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">The proper injectors to use are the long tipped Euro-R ones, or S2k ones.. I used RC440s which don't protrude as far as I liked into the mainfold, so I shaved down the little tips a little bit at the injector ports..
But yes, I use the hondata gasket with that manifold and everything fits fine..</TD></TR></TABLE>
Yeah I am using RC Injectors also. I had to shove them in there. ANd I had put alittle honda bond around them to make sure of no vacuum leak.
Old Oct 19, 2005 | 07:47 AM
Honda318dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah I am using RC Injectors also. I had to shove them in there. ANd I had put alittle honda bond around them to make sure of no vacuum leak.</TD></TR></TABLE>
Want to know a secret...?
The o-ring that seals the dipstick works perferct as the o-ring to seal the RC injectors to the intake manifold, I think I just stacked 2 per injector..
Old Oct 19, 2005 | 08:14 AM
prelittlelude's Avatar
The o-ring that seals the dipstick works perferct as the o-ring to seal the RC injectors to the intake manifold, I think I just stacked 2 per injector.. </TD></TR></TABLE>
damn you Corey! why could you not have released this information earlier BEFORE i sat there with a dremel and oppend up the old h22 injector seals.. ah the humanity!
Old Oct 19, 2005 | 09:08 AM
Default Re: (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">damn you Corey! why could you not have released this information earlier BEFORE i sat there with a dremel and oppend up the old h22 injector seals.. ah the humanity!</TD></TR></TABLE>
Yeah I wish i knew that before. I sat there trying to dremel the o rings forever, until i was left with some hacked up looking o rings that i had to use honda bond lol
Old Oct 19, 2005 | 10:16 AM
will i have to reseal it with hondabond/o-rings when using OBD1 H22 injectors? I suppose i'll find out when i actually do this in a few days but it never hurts to find out ahead of time
Old Oct 19, 2005 | 10:25 AM
Honda318dx's Avatar
Damn, sorry guys, I feel like an *** now!
Old Oct 19, 2005 | 09:55 PM
Old Oct 20, 2005 | 12:55 PM
anyone know?
Old Oct 20, 2005 | 01:58 PM
even with the stock obbd1 injectors you need to use the special oring or hondabond.
Old Oct 20, 2005 | 02:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">The o-ring that seals the dipstick works perferct as the o-ring to seal the RC injectors to the intake manifold, I think I just stacked 2 per injector.. </TD></TR></TABLE>
Will the dipstick o-ring fit H22 OBD1 injectors as well? And although off topic, is there a way to clean the injectors while i still have them out of the intake manifold?
Old Oct 21, 2005 | 12:08 PM
Default Re: (snowblind7x)
bump
Old Oct 22, 2005 | 03:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowblind7x &raquo;</TD></TR><TR><TD CLASS="quote">Will the dipstick o-ring fit H22 OBD1 injectors as well? And although off topic, is there a way to clean the injectors while i still have them out of the intake manifold?</TD></TR></TABLE>
Old Oct 22, 2005 | 08:04 PM
v4lu3s's Avatar
RTFM
i used some larger sized AC o-rings on stock obd1 injectors to fit on my euror-r manifold.
fake mugen power
Jul 25, 2019 05:42 PM
huevosrancheros
Oct 14, 2006 09:33 AM
pny1981
Nov 16, 2005 12:06 PM
ThinHoanG
May 25, 2005 05:58 AM
nickwilmot
Oct 17, 2003 01:58 PM
