VSS, B-Series shift linkage, 2000 em1 b16 clutch and pressure plate, gsr differential
some of this **** is left over from my previous b18c1 setup, before it got stolen from my car. ****** thieves
Anyways, here's what i have
b18c1 VSS, should work with all b-series. Came from an obd1 car. SOLD
B-series shift linkage. Works fine, what else is there to say about it? It shifts gears.
b16 clutch and pressure plate, from 2000 si. 10,000 miles I also have the clutch alignment tool.
I also have miscellaneous transmission parts for d-series. Need anything, just ask.
d15b8 throttle body and IACV valve
This **** has to go.
Modified by Bense at 6:57 PM 1/12/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gordon Liddy »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
come on you guys!!! i need some money so i can buy things like "a jdm parking decal"
who the expletive buys stuff like this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felix. »</TD></TR><TR><TD CLASS="quote">you have a gsr differential?</TD></TR></TABLE>
yes, i'm gonna have to go find it though
bense@(~)$ dict bump
8 definitions found
From The Free On-line Dictionary of Computing (13 Mar 01) [foldoc]:
bump
Increment. E.g. {C}'s {++} operator. It is used especially of
counter variables, pointers and index dummies in "for",
"while", and "do-while" loops.
(1994-11-29)
From Jargon File (4.2.3, 23 NOV 2000) [jargon]:
bump vt. Synonym for increment. Has the same meaning as C's
++ operator. Used esp. of counter variables, pointers, and index dummies
in `for', `while', and `do-while' loops.
From Webster's Revised Unabridged Dictionary (1913) [web1913]:
Bump \Bump\, v. i. [See {Boom} to roar.]
To make a loud, heavy, or hollow noise, as the bittern; to
boom.
As a bittern bumps within a reed. --Dryden.
Bump \Bump\, n.
The noise made by the bittern.
Bump \Bump\, v. t. [imp. & p. p. {Bumped}; p. pr. & vb. n.
{Bumping}.] [Cf. W. pwmp round mass, pwmpiaw to thump, bang,
and E. bum, v. i., boom to roar.]
To strike, as with or against anything large or solid; to
thump; as, to bump the head against a wall.
Bump \Bump\, v. i.
To come in violent contact with something; to thump.
``Bumping and jumping.'' --Southey.
Bump \Bump\, n. [From {Bump} to strike, to thump.]
1. A thump; a heavy blow.
2. A swelling or prominence, resulting from a bump or blow; a
protuberance.
It had upon its brow A bump as big as a young
cockerel's stone. --Shak.
3. (Phren.) One of the protuberances on the cranium which are
associated with distinct faculties or affections of the
mind; as, the bump of ``veneration;'' the bump of
``acquisitiveness.'' [Colloq.]
4. The act of striking the stern of the boat in advance with
the prow of the boat following. [Eng.]
From WordNet (r) 1.6 [wn]:
bump
n 1: a lump on the body caused by a blow
2: something that protrudes [syn: {bulge}, {hump}, {gibbosity},
{gibbousness}, {jut}, {prominence}, {protuberance}, {protrusion},
{extrusion}, {excrescence}]
3: an impact (as from a collision); "the bump threw him off the
bicycle" [syn: {blow}]
v 1: knock against with force or violence; "My car bumped into
the tree" [syn: {knock}]
2: come upon, as if by accident; meet with; "We find this idea
in Plato"; "I happened upon the most wonderful bakery not
very far from here"; "She chanced upon an interesting book
in the bookstore the other day" [syn: {find}, {happen}, {chance},
{hit}, {encounter}]
3: dance erotically, as in "bump and grind": dance with the
pelvis thrust forward
4: assign to a lower position; reduce in rank; "She was demoted
because she always speaks up" [syn: {demote}, {relegate},
{break}, {kick downstairs}] [ant: {promote}]
5: remove or force from a position of dwelling previously
occupied; "The new employee dislodged her by moving into
her office space" [syn: {dislodge}, {displace}]
8 definitions found
bump
(1994-11-29)
boom.
Bump \Bump\, n.
Bump \Bump\, v. i.
protuberance.
bump
{hit}, {encounter}]
