headlights stopped working wtf mate?
Old Oct 18, 2005 | 12:56 PM
sockvtec's Avatar
Default headlights stopped working wtf mate?
ok so my headlights dont come one, everyhitng else works properly, what fuse is for the headlights? i checked the bulbs and they are ok and the connections are also ok so it must be the fuse....but the fuses underneath my dash have all been modified and split (first owner?) so i dont know what the correct fuse diagrams are....someone help so i can drive at night
Modified by sockvtec at 4:06 PM 10/18/2005
Old Oct 18, 2005 | 01:03 PM
JDM-EJ1's Avatar
Default Re: headlights stopped working wtf mate? (sockvtec)
Maybe the bulbs are bad?
Old Oct 18, 2005 | 01:07 PM
sockvtec's Avatar
Default Re: headlights stopped working wtf mate? (JDM-EJ1)
the bulbs are fine and so are the connections...
i didnt state that clearly in the post so i edited it
Old Oct 18, 2005 | 01:08 PM
sockvtec's Avatar
anyone else?
Old Oct 18, 2005 | 01:19 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec &raquo;</TD></TR><TR><TD CLASS="quote">the bulbs are fine and so are the connections...
How do you know the bulbs are fine? Are you just assuming they're fine?
Old Oct 18, 2005 | 01:23 PM
Z Darkside's Avatar
why don't you just pull out the fuses one at a time and see if any are broken?
Old Oct 18, 2005 | 01:29 PM
miamijdmcoupe524's Avatar
check the switch for the headlights. mine was broken on the inside once.
Old Oct 18, 2005 | 04:52 PM
sockvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">How do you know the bulbs are fine? Are you just assuming they're fine?</TD></TR></TABLE>
i pulled both out...they were fine (they are only a year old if that) also i checked the connections all the way to the fuse box...all connected, i just dont know what fuse if for the headlights cause my (underdash) fusebox was modified byt the 1st owner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miamijdmcoupe524 &raquo;</TD></TR><TR><TD CLASS="quote">check the switch for the headlights. mine was broken on the inside once.</TD></TR></TABLE>
where exactly is that?
Old Oct 18, 2005 | 04:56 PM
coquitlamEG's Avatar
where exactly is that?</TD></TR></TABLE>
If you don't know where your headlight switch is, how do you know if they're working or not?
Old Oct 18, 2005 | 05:32 PM
johnecon2001's Avatar
The headlight fuse should be under the hood.
Old Oct 18, 2005 | 10:59 PM
sockvtec's Avatar
Default Re: (johnecon2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnecon2001 &raquo;</TD></TR><TR><TD CLASS="quote">The headlight fuse should be under the hood.</TD></TR></TABLE>
ok is it the 10 thats screwed down?
Old Oct 19, 2005 | 09:33 AM
sockvtec's Avatar
??????????? anyone have a pic of the fusebox and appropriate locations???
Old Oct 19, 2005 | 09:54 AM
TheIntegraGuy's Avatar
I do not have a picture of the fuse layout, but the headlight fuse is underneath your dash. They are 10AMPs.. 2 for lowbeams and 2 for high beams. The fuses are red and should be 4 lined up next to each other.
Cuitarded
Honda Fit
Feb 19, 2014 02:33 PM
Ciekiller
Honda Civic (2006 - 2015)
Apr 18, 2008 02:32 PM
pcrodrig
Dec 22, 2007 09:59 PM
bncivic
Aug 8, 2005 05:44 PM
TOTAL-TUNING
43
Feb 17, 2005 07:35 PM
