Recurring IACV Code 14
Old Oct 18, 2005 | 12:37 PM
pdiggitydogg's Avatar
Default Recurring IACV Code 14
I had this problem just last Thursday, and I replaced the IACV with a known working unit. Today, the damn cel comes back on.
What should I be looking at??
(The replacement IACV is clean and I know that it works fine)
totally stock y8
no obd change, no swap, no nothing
Modified by pdiggitydogg at 9:02 PM 10/18/2005
Old Oct 18, 2005 | 01:35 PM
actual tech help needed
Old Oct 18, 2005 | 01:36 PM
ralphie14's Avatar
Default Re: (pdiggitydogg)
Make sure you pluged the harness back into it or that it is plugged in all the way.
Old Oct 18, 2005 | 01:45 PM
Yes, of course
It worked fine since thursday night until 4pm today...
Old Oct 18, 2005 | 01:49 PM
dogbiscuit's Avatar
try cleaning it? just might be dirty maybe something else is causing the IAC to throw a code?
Old Oct 18, 2005 | 02:52 PM
yeah, I said its clean. I replaced it too
Something else is clearly going on here...which is what Im asking
Old Oct 18, 2005 | 03:09 PM
perlmeister8's Avatar
Did you swap from obd2-1 by chance and did not do the 3-2 wire conversion?
Old Oct 18, 2005 | 05:00 PM
no, nothing
Old Oct 18, 2005 | 06:27 PM
Old Oct 18, 2005 | 07:45 PM
come on help
Old Oct 18, 2005 | 08:03 PM
FalkenSiR's Avatar
Follow the wires. There may be a short somewhere. When I used to work at a dealership, cars would have shorts and the burned wire would be somewhere inside the dash. Hard to get to, but it's possible most of the time if you take your time. Dunno try that.
Old Oct 19, 2005 | 06:33 AM
anyone else...
Old Oct 19, 2005 | 06:41 AM
gabspeed's Avatar
is the car acting up at all? is it iddleing correctcly? make sure that the iacv and the actual holes in the intake manifold are completely free of dirt use brakeparts cleaner and after you do it reset the ecu see what happens
Old Oct 19, 2005 | 07:12 AM
yeah, Ive gone through the basic procedure
idle is smooth
unit is clean
IM is clean
Ive reset the ecu 3 times since last thursday. The thing runs fine for awhile and then the cel (same, 14) returns.
I really dont think its the IACV, there has to be something else causing this problem.
Old Oct 19, 2005 | 08:53 AM
I dont think it loose wiring...
Old Oct 19, 2005 | 10:54 AM
Old Oct 19, 2005 | 12:12 PM
antivic's Avatar
Default Re: Recurring IACV Code 14 (pdiggitydogg)
same **** was happening to me...the car would idle fine and run fine, then code 14 and 9 would pop up...under the hood i noticed water leakin out the tb...i touched where it was leaking...reseted the ecu adn the code went away...wtf oO
Old Oct 19, 2005 | 12:16 PM
sicones's Avatar
Default Re: Recurring IACV Code 14 (antivic)
hey pat I repiled at hst
Old Oct 19, 2005 | 12:19 PM
FalkenSiR's Avatar
Default Re: Recurring IACV Code 14 (sicones)
Forgot to mention. Check for loose connections at the drivers side shock tower plug. Like I said follow the wire as far as you can. It would make sense if a wire is loose since the problem is intermittent (on and off).
Old Oct 19, 2005 | 04:52 PM
sicones's Avatar
bump, I would love to know whats wrong too
92lxsleeper
16
Jun 12, 2009 06:38 AM
EJ8CIVIC
Jan 10, 2006 09:21 PM
ken-e
Dec 20, 2005 10:03 AM
Touge Tuning
Dec 10, 2005 09:44 AM
