Squeaky Rear Brakes?
Old Mar 6, 2002 | 08:19 AM
AllShwNoGo's Avatar
Default Squeaky Rear Brakes?
I've got a dx coupe with the rear drums. I am getting squeaks when I engage or disengage the brake peddle. The squeaks do not occur while stopping or driving, only as I press or release the peddle.
Any ideas on what that is and how to go about fixxing it?
Thanks
Old Mar 6, 2002 | 08:37 AM
bps2799's Avatar
Default Re: Squeaky Rear Brakes? (AllShwNoGo)
Do you use the parking brake?
If not, start.
Do you back up a lot? If not, brakes will lose adjustment.
Brake hard several times in reverse.
Not sure about Hondas, but many domestics, still stuck in the stone age of drum brakes, recommend this to adjust the rear drums.
If this doesn't work, go to a shop and get them checked for tension in the cables for the parking brake, as well as overall function.
Old Mar 6, 2002 | 08:50 AM
AllShwNoGo's Avatar
I do use the parking brake all the time, but I dont drive in reverse very often. I'll try doing that and braking hard and see if that helps out.
Eventually I'd like to do a rear disc conversion off an ex, but I just cant stomach the $$ right now. LOL
Thx
Old Mar 6, 2002 | 01:12 PM
fixhondas's Avatar
You need to adjust your rear brakes and lube your backing plate where the shoes are contacting.
Old Mar 6, 2002 | 08:57 PM
martini's Avatar
Default Re: Squeaky Rear Brakes? (bps2799)
Yep, it works for Honda's.
That's what I would've suggested he do. But also brakes squeeking isn't always an indication that something is wrong. It's just something that is annoying to americans.
Blackhalo6
Apr 12, 2013 10:16 AM
jmk64
Nov 5, 2006 04:50 AM
vr6chris
May 11, 2005 03:14 PM
