OBD gurus: JDM OBD2B ECU + JDM OBD2B Motor + USDM OBD2A 5th Gen Shell = ...?
Old Oct 18, 2005 | 06:44 AM
mashoutposse's Avatar
Default OBD gurus: JDM OBD2B ECU + JDM OBD2B Motor + USDM OBD2A 5th Gen Shell = ...?
Is it possible to swap in a Euro R motor/tranny/ECU (OBD2B) into my 5th gen USDM Prelude (OBD2A)? My thinking is that using the Euro R ECU should eliminate the problem of the IACV & other incompatibilities as well as allow use of Honda's stock Euro R maps. Will a conversion harness make this possible? Like the following...
http://rywire.com/store/produc...f2dfd
Thanks in advance
Old Oct 18, 2005 | 06:50 AM
The Weather Man's Avatar
Anythings possible.
Old Oct 18, 2005 | 07:37 AM
Default Re: (TheKingPin)
Thanks, but will it work as described? Euro R + ECU into a USDM 5th gen with the help of a conversion harness with no other compatibility issues?
Modified by mashoutposse at 5:01 PM 10/18/2005
Old Oct 18, 2005 | 07:53 AM
kulrevon's Avatar
Default Re: (mashoutposse)
does the euro r ecu have an immobilizer?
sorry im not a euro r guy
and I believe it should work. I know people have done this before so you should search.
Old Oct 18, 2005 | 08:10 AM
Default Re: (kulrevon)
Trust me, bro, I have searched and searched and searched... I have searched and researched extensively; I'm now looking for confirmation by asking you guys directly.
Steve at HMO believes that the Euro R ECU does not come equipped with an immobilizer.
My goal is to completely sidestep the 3-wire IACV issue and other known incompatibilities by using the stock Euro R OBD2B ECU. Will this work?
Old Oct 18, 2005 | 08:53 AM
mgags7's Avatar
i really cant tell you that....but dont depend on the jdm ecu obd stuff being compatible with us stuff.....its all a bit different....
this case could be different...but from what i have seen before its always a bit weird....
Old Oct 18, 2005 | 09:30 AM
kulrevon's Avatar
Default Re: (mgags7)
well the problem you are going to run into is that you need to run the harness from your engine. the euro comes out on the wrong side of the engine bay. and then your in the situation where the 3 wire iac comes into play. So are you really gaining anything? then you can just wire striaght to the ecu if you dont want to convert. the iac to use the harness.
Old Oct 18, 2005 | 11:15 AM
Default Re: OBD gurus: JDM OBD2B ECU + JDM OBD2B Motor + USDM OBD2A 5th Gen Shell = ...? (mashoutposse)
Thanks for the responses, guys; now we're getting somewhere
How do you solve the problem of having the engine harness coming out of the other side of the bay?
Old Oct 18, 2005 | 11:29 AM
BB6racer's Avatar
my friend and his jdm b16 had this problem. had to customize the harness by adding some wire here, removing some there. but he's really good with swap and all that. sorry i don't know anything about euro-r's or your obd question though.
Old Oct 19, 2005 | 05:23 AM
kulrevon's Avatar
Default Re: (BB6racer)
just use the harness that is in your car on this motor. and modify it.
Old Oct 19, 2005 | 10:46 AM
Eddiebx's Avatar
ur not gonna plug in an obd2b ecu into obd2a plugs without extensive rewireing of the plugs, and getting the extra plug you need because the 2a and 2b dont both use the same 3 plugs
oneprelude
Apr 11, 2009 03:59 PM
k_lude
Jul 26, 2007 07:13 PM
mashoutposse
Nov 5, 2005 03:52 PM
mprelude
Apr 26, 2005 05:07 AM
4thgenlude
Dec 15, 2004 05:36 PM
