Mild steel 1018 - exact ingredients ???
Old Oct 18, 2005 | 04:13 AM
hondaapi's Avatar
Default Mild steel 1018 - exact ingredients ???
Can somebody tell me the exact ingrdients of Mild Steel AISI 1018?
Need it for selecting the german material numbers.
Thanks
Old Oct 18, 2005 | 05:23 AM
beepy's Avatar
Default Re: Mild steel 1018 - exact ingredients ??? (hondaapi)
Carbon: 0.15 - 0.20%
Manganese: 0.60 - 0.90%
Phosphorus: max. 0.04%
Sulfer: max. 0.05%
And the rest is iron. AKA "low carbon" or "mild" steel.
Modified by beepy at 6:08 PM 10/19/2005
Old Oct 19, 2005 | 12:35 AM
hondaapi's Avatar
Default Re: Mild steel 1018 - exact ingredients ??? (beepy)
Thanks.
I hope to find the right material.
Nobody here know MILD STEELE or the AISI number 1018.
That sucks.
KEvin
Old Oct 19, 2005 | 09:00 AM
beepy's Avatar
What system do you use? I can cross-reference it in my little Materials handbook.
If you use DIN, the material number I get is DIN 1.1157
Specific properties:
0.36-0.44 C, 0.80-1.10 Mn, 0.04 P, 0.04 S, 0.25-0.50 SI, base Fe
From the same book, AISI 1080 properties:
.750 to 0.880% C, 0.600 to 0.900% Mn, 0.040% P max, 0.050% S max
So the DIN metal is a little lower in carbon, but the other alloying agents are the same.
Old Dec 1, 2005 | 10:38 AM
hondaapi's Avatar
Yes we use the DIN her in Germany.
This information helped me a lot.
Thanks guys
weldingnoob
Welding / Fabrication
Jul 31, 2009 08:16 AM
B18EG6
Jan 4, 2006 06:53 AM
hondaapi
Dec 19, 2005 07:01 AM
85
May 19, 2005 10:21 AM
dustywebber
May 2, 2004 04:56 PM
