Seat Brackets..
Alright I'm about to buy 2 Sparco Torino seats from the same guy I bought my wheels from, he has them in his 99? Civic Si and said he will sell the brackets, rails and everything to me. Will the same brackets fit in the Sol from the Civic or will I need to order specific ones? Thanks.
If they are universal like the memory-fab setup then yes they will fit.
Just check to make sure they are universal, or if Sparco makes their brackets application specific.
Sol seats dont bolt into civic's without modification so I'm assuming they would have to be modified to fit. It's no big deal. You just have to drill an extra hole in the back.
Sol seats bolt right in using the civic rails......
Not sure I'd be wanting to mess with what holds my *** in place incase of a wreck!
Drilling a new hole, will it be strong enough or tear thru the floor board???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">Sol seats bolt right in using the civic rails......
Drilling a new hole, will it be strong enough or tear thru the floor board???</TD></TR></TABLE>
This will work, but you have to have some one weld a reinforcment plate on the underside of the car, or you can weld it yourself, shouldn't be too bad
Q-OnE
Nov 6, 2002 07:47 PM
