which lower rear tie bar?
Should I get a rear lower tie bar and then the jdm type r 22mm sway bar or should I get the comptech lower bar and mount the 22m sway bar on that?
This is for my del sol
right my bad.....so wll it work and is it reccommended that i get the comptech tie bar and 23 mm sway bar or should i get another tie bar and the 23mm sway with the beaks mounting kit? please give me a quick opinion.
Either get the Suspension Techniques sway/tie combo (22mm sway, adjustable, same as comptech bar, but cheaper!) or the ITR sway w/ beaks kit. Price out the total of each and get the lower priced one. with the sway there, you won't notice any effects from the tie bar, so you won't need it. if you want one, just get a low priced one. considering the effects of the lower arm bar are minimal, almost any one will do.
Sassafrass
26
Feb 9, 2004 05:16 PM
