Cluster Needles dont work!!!!!!!!!!!!
Old Oct 17, 2005 | 08:24 PM
Soccer10's Avatar
Default Cluster Needles dont work!!!!!!!!!!!!
I bought a 93 si cluster for my 92 si hb. The lights all work in the cluster ( battery, turn signal, high beams) but the needles dont work. No rpm, no gas or temp and of course no speedo. Help me!!!!!!!!
Old Oct 18, 2005 | 10:07 AM
Soccer10's Avatar
Default Re: Cluster Needles dont work!!!!!!!!!!!! (Soccer10)
TTT
Old Oct 18, 2005 | 10:11 AM
EKCivicR's Avatar
Hee hee.. you got screwed. Check your fuses, make sure your plug wires behind the cluster didn't come lose.
Old Oct 18, 2005 | 10:47 AM
bugzpimpin's Avatar
if its the tach or the temp/gas that isn't working...and u've only got the new cluster b/c of the mileage(which wouldnt really make sense b/c its a honda and u can turn them back with u'r finger), you should just unscrew those two gauges off and swap them onto u'r new one...the screw are in the back of the gauges.
Old Oct 20, 2005 | 11:18 AM
Soccer10's Avatar
The cluster worked before, the needles moved, but now it doesnt want to. Fuses checked, all seem good. Now what?
Old Oct 22, 2005 | 11:16 AM
Soccer10's Avatar
TTT
1999jdm
11
Apr 17, 2013 04:22 AM
civiccpedx
May 18, 2007 06:56 PM
trick_db
May 14, 2005 02:56 AM
137
10
Apr 22, 2004 12:58 PM
E-lude78
Jun 5, 2003 01:20 PM
