cooling fan!!!!!!!!
Old Oct 17, 2005 | 07:46 PM
90efSI's Avatar
Default cooling fan!!!!!!!!
alright well my cooling fan hasnt been turning on so today i just wired it to a source that is only on when the car is on..... but my qustion is there is all this wireing keft behind and it makes it look like **** so i was wondering if you could tell me what i can take out and what i cant.....like all the relays and ****....
ill have pics up soon once i can figure out how to make them work on gay *** prostreet.....does anybody kno of anyother sites where i can post my pics....?
-thanks
Old Oct 17, 2005 | 10:02 PM
Tyson's Avatar
Default Re: cooling fan!!!!!!!! (90efSI)
you dont want to leave the fan on constantly. it will wear out the fan because its using it too much.
did you pull all the stock wiring??
Old Oct 17, 2005 | 11:22 PM
1QuikSOHCZC's Avatar
i did the same on mine..i used an add a circuit from pep boys..its like 10 bucks...i jus had 1 wire for ground like 8inches long for the chassis..and another that went from the fan to the fuse box under the dash, i jus covered it with that plastic black tubbing to group wiring together...it looks stock
Old Oct 18, 2005 | 07:43 AM
rbjeepthing's Avatar
One of your relays is gone or the fuse. Trace the wires with a test light and use your fan correctly. With out the relays your fan uses too much amperage you will melt wires burn out the fan and put too much strain on your electrical system.
EJ8Squad919
Jun 30, 2014 06:46 PM
Frost7177
Oct 17, 2009 02:10 PM
ek_silverback
Dec 22, 2008 09:29 PM
lilo_goki
Dec 3, 2007 02:47 PM
