Integra Front Brakes with stock 14" rims?
Old Oct 17, 2005 | 07:31 PM
PhatBoy5015's Avatar
Default Integra Front Brakes with stock 14" rims?
I have a 97 Civic HX with the stock 14" alloy rims (not the steel wheels with hubcaps). I was wondering if i changed the front brakes to regular Integra front brakes if the rotor and caliper would fit with the stock rims.
Old Oct 17, 2005 | 07:40 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: Integra Front Brakes with stock 14" rims? (PhatBoy5015)
its weird, the integra brakes with fit with 14" steelies, but it wont fit the HX wheels. U have 2 options to use those wheels with integra brakes: Either put some spacers on, or grind down the side of the cailper a little bit. Do a little searching and u will find a DIY. I saw one last week, but i forget which forum it was in
Old Oct 17, 2005 | 07:51 PM
Street Ghost's Avatar
Default Re: Integra Front Brakes with stock 14" rims? (rukawa1one)
what he said ^
Old Oct 17, 2005 | 09:05 PM
Phantastic's Avatar
i used wheel spacers and everything worked out great.
Old Oct 17, 2005 | 09:22 PM
E dwinbon G's Avatar
Default Re: Integra Front Brakes with stock 14" rims? (Phantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phantastic &raquo;</TD></TR><TR><TD CLASS="quote">i used wheel spacers and everything worked out great.</TD></TR></TABLE>
Old Oct 18, 2005 | 05:27 AM
Default Re: Integra Front Brakes with stock 14" rims? (E dwinbon G)
what kind of wheel spacers? does the tir stick out too far past the fender?
Old Oct 18, 2005 | 10:50 PM
you can get spacers in different sizes...if you get a spacer that is too big then yeah it would go pat the fender..but you would not even be able to get the wheel secure since the studs would probably be too short
Old Oct 18, 2005 | 11:09 PM
sockvtec's Avatar
https://honda-tech.com/zerothread?id=555391
808zrk
Aug 23, 2012 10:19 PM
euclid
Apr 22, 2003 05:46 PM
agent_noman
Feb 11, 2003 08:28 PM
airon
May 10, 2002 09:37 PM
Nick
Nov 22, 2001 06:48 AM
