AVC-R duty cycle calculation
Old Oct 17, 2005 | 07:29 PM
LostSolVTEC's Avatar
Default AVC-R duty cycle calculation
I was bored in class today and was trying to figure out exactly how to figure out what the duty cycle needs to be if you don't use the learn cycle. I've never seen anyone really explain how to set it up other than messing with it till it works, or just put it in learn mode lol. If this is wrong and there is an actual way of figuring it out lemme know, i was just bored.
the AVC-R reads boost in kg/cm^3, most waste gates read in bar, and most of us know psi, so things tend to get fuzzy but fear not!
1 bar = 14.5psi
1 kg/cm^3 ~ 14.2psi
so say you have a .5 bar (8psi) spring from tial, that should read about .56kg/cm^3 on the AVC-R
you want to run 10psi (.68ish bar) or .70 kg/cm^3 on the AVC-R
i figured that Duty Cycle = Boost Setting / Spring Rate x 100%
~ ( .7 / .56 ) x 100% = 125%
that means the wastegate is working at 125% of the spring rate. I assumed this ment the AVC-R has to make up for the extra 25%
i went out and checked my learn mode setting and it's set between 23-24% the whole way.
So by setting the desired boost (.7 kg/cm^3) and 25% duty cycle it's pretty damn close
if anyone else can give some insight on this jump in please
Old Oct 18, 2005 | 03:26 AM
Default Re: AVC-R duty cycle calculation (LostSolVTEC)
bump!
Old Oct 18, 2005 | 03:56 AM
vr6chris's Avatar
im not real good at math calculations. but when i was using my avcr, at around 15psi and up i was at 54% to 58% duty cycle
Old Oct 18, 2005 | 07:23 AM
MrBui's Avatar
i'd like to know too cuz im having a hell of a time getting constant boost
Old Oct 18, 2005 | 07:47 AM
Default Re: AVC-R duty cycle calculation (vr6chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vr6chris &raquo;</TD></TR><TR><TD CLASS="quote">im not real good at math calculations. but when i was using my avcr, at around 15psi and up i was at 54% to 58% duty cycle</TD></TR></TABLE>
what spring is in your wastegate?
Old Oct 18, 2005 | 08:29 AM
Mikes01GSR's Avatar
That doesn't hold true for mine dane, I run 15 psi on a 6.53psi spring and my duty
is around 50-54. 15/6.53x100=229.7%. That would be like saying my duty would
have to be 129 to reach max boost and that doesn't hold true. Anyone else with
input?
Old Oct 18, 2005 | 08:34 AM
MrBui's Avatar
13lb(.9bar) spring
Old Oct 18, 2005 | 09:13 AM
legendboy's Avatar
Default Re: AVC-R duty cycle calculation (MrBui)
i have a 7lb spring in my wg. I use 64% duty at 1.0bar target to hit 1.1 bar.
Not sure if that helps lol
Old Oct 18, 2005 | 11:03 AM
Default Re: AVC-R duty cycle calculation (Mikes01GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes01GSR &raquo;</TD></TR><TR><TD CLASS="quote">That doesn't hold true for mine dane, I run 15 psi on a 6.53psi spring and my duty
input?</TD></TR></TABLE>
mike you always gotta mess things up for me lol
but i also converted mine to kg/cm^3 you did yours in psi (still works out to teh same number lol)
damnit this thing is bothering me now
but 50-54% ~ a little more than double the 6.54psi is around 15psi
Old Oct 18, 2005 | 12:08 PM
vr6chris's Avatar
i was using a .6 bar spring
Old Oct 19, 2005 | 04:24 AM
bump
user 98292739
Oct 10, 2006 05:42 PM
Toda Party
Nov 14, 2005 06:58 AM
SiR Kid
Apr 14, 2003 06:32 PM
TurboDC4
Mar 28, 2003 10:02 AM
Type-ARR
Sep 23, 2001 10:38 PM
