H23A EG idle/stalling and cranking problem--->PISSING ME OFF!!!!!
Old Oct 17, 2005 | 07:20 PM
JDM H23A's Avatar
Default H23A EG idle/stalling and cranking problem--->PISSING ME OFF!!!!!
What would cause major fluctuations in idle...anywhere from 600-1,000 RPM's? The main problem that I'm having is after driving for a while, the RPM's will sometimes drop to below 600 when I'm in neutral, and the car will stall?
Also, a lot of the time it'll take anywhere from 10-20 cranks in order for it to turn over, and other times it'll start like it should (the usual 3 cranks for a Honda). What the hell is happening?
Old Oct 18, 2005 | 01:44 PM
JDM H23A's Avatar
Default Re: H23A EG idle/stalling and cranking problem--->PISSING ME OFF!!!!! (JDM H23A)
BuMp
Old Oct 18, 2005 | 09:51 PM
JDM H23A's Avatar
Old Oct 18, 2005 | 10:01 PM
LilCivic04's Avatar
check for vacuum leaks, iacv, fitv.
Old Oct 18, 2005 | 10:06 PM
marshun's Avatar
Default Re: H23A EG idle/stalling and cranking problem--->PISSING ME OFF!!!!! (LilCivic04)
my guess is the iacv.
but it shouldnt take you 3 trys to start it up. my h22 in my civic only takes one crank
edit: usually just some taps on the iacv will make it run better.
Modified by marshun at 11:08 AM 10/19/2005
Old Oct 18, 2005 | 10:07 PM
high_revs's Avatar
Old Oct 18, 2005 | 10:24 PM
warrick's Avatar
Default Re: (SB tuning)
cap, rotor, plugs, wires, coil, ignitor.
valve adjustment.
Old Oct 19, 2005 | 06:57 AM
JDM H23A's Avatar
Default Re: (warrick)
Thanks guys! Any other suggestions? I'm just trying to compile a list here... Anything to do with the idle screw? Or resetting the idle like someone mentioned to me?
EDIT--->As for the cranking issue, I've already replaced the main relay
Old Oct 19, 2005 | 08:07 AM
Nikoli's Avatar
Default Re: (JDM H23A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM H23A &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys! Any other suggestions? I'm just trying to compile a list here... Anything to do with the idle screw? Or resetting the idle like someone mentioned to me?
EDIT---&gt;As for the cranking issue, I've already replaced the main relay </TD></TR></TABLE>
yea you should deffinately check your idle air screw. and clean out your tb. make sure your throttle cable is adj. properly also.
z6hatchboy
Feb 7, 2008 01:28 PM
hai_tech
19
Mar 20, 2007 07:26 PM
johnlude85
Feb 26, 2006 10:01 AM
chadwick16
Dec 6, 2005 04:35 PM
jcivicsib20
Mar 13, 2003 08:42 AM
