Valve cover grommet help
Old Oct 17, 2005 | 06:51 PM
Excelerate's Avatar
Default Valve cover grommet help
Maybe this is the dumbest question ever but how do you get the valve cover grommets onto the valve cover bolts? The metal cap fits but the grommet is not wide enought to fit over the bottom part of the bolt so how do I get the grommet over that bottom part?
Old Oct 17, 2005 | 07:01 PM
P_Adams's Avatar
Default Re: Valve cover grommet help (Excelerate)
Soak them in hot water to soften them. Apply a light coat of oil to the bolts and...............Phfffft, they're on!!!
P
Old Oct 3, 2007 | 10:00 PM
jaysome01's Avatar
Default Re: Valve cover grommet help (P_Adams)
I'm having the same problem right now.. Is this true? Throw it in some hotwater and lube up the bolt and I should be good? I broke 3 grommets right now and I gotta re-order. 10 bucks each from Honda... SUCKS!!!
HELLLLLLLPPP!!!
Old Oct 4, 2007 | 03:48 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Valve cover grommet help (jaysome01)
I've never tried soaking them in hot water.
I usually put a little oil on the bolt and then take the bolt, grommet and a socket and place them between a vice in this order...
vice l bolt > grommet > socket l vice
then I just tighten the vice up slowly until the bolt pops through the grommet.
It's much easier than trying to muscle them through with your hands.
Old Oct 4, 2007 | 06:09 AM
Duane_in_Japan's Avatar
Default Re: Valve cover grommet help (TouringAccord)
10 bucks for an OEM Honda rubber Grommet, just one, I need to get into the grommet business, I only use OEM (JDM) grommets and never had to pry one on, always have to force off the old ones though.
Old Oct 4, 2007 | 08:35 AM
jaysome01's Avatar
thats how i tried it the first 3 times.. but 3 broke.. I'm going to try and make some special washer or something to make the bolt more "pointy" instead of having the flat surface on the bottom of the bold and trying to get the grommet thru there... Oh well, just ordered 3 more grommets!!! Imma give it another try.. If anyone else has more info please send.. This is really aggrivating...
Old Oct 5, 2007 | 09:16 PM
jaysome01's Avatar
I Finally Got it!!!!! I received the new grommets from TAS Auto.. Great site!!! I did have to make a "SPECIAL" Washer that mimicks the other side of the threads... I can take a picture of it if someone wants.
Old Oct 6, 2007 | 06:24 AM
PLEASE, every pic added to the site is a plus.
Old Dec 2, 2009 | 03:26 PM
jdbwood's Avatar
i was in the same dilemma goin nuts about this.. broke 2 gromments and had to be stuck witout car.. hot water trick worked great on these cheap fel pros thanxx p adams
99accordsedanforsale
Classic Hondas
Nov 12, 2007 07:24 AM
k_lude
Jan 9, 2007 06:48 PM
SlowB16si
Jan 28, 2006 02:13 PM
hcivic99
Jun 8, 2005 06:15 PM
LoudAccord
Jan 9, 2003 10:43 AM
