Anyone know what type of aluminum our tranny casings are?
Old Oct 17, 2005 | 04:34 PM
DohcVtecCrx's Avatar
Default Anyone know what type of aluminum our tranny casings are?
My friend broke the spider gears in his diff and ended up with a small hole in his trans. His dad wants to try to reweld it before buying a new one. Now posts weather it is a good idea or not are irrelevent as is spockeg and my opinions. His dad is gonna have it done regardless.
So on that note I talked to the welder who is going to weld it. He said there are several diffrent types of aluminum and he said it would be easier if he knew the exact type it is.
I know for most of us, myself included, this question is over our heads. But some here will know what I am talking about. If you do know please post.
Thanx in advance!!!
Old Oct 18, 2005 | 09:21 AM
Importordomestic's Avatar
Default Re: Anyone know what type of aluminum our tranny casings are? (DohcVtecCrx)
well i know its Cast aluminum. but i dont know exact materail composition. its a mix of metals..... iwould just tell his dad to buy a half case off ebay.
Old Oct 18, 2005 | 10:26 AM
philipwight's Avatar
Default Re: Anyone know what type of aluminum our tranny casings are? (Importordomestic)
i welded my case with er5356 rod and a tig welder.
Old Oct 18, 2005 | 11:35 AM
Default Re: Anyone know what type of aluminum our tranny casings are? (philipwight)
awesome thanx so much dude, your a life saver.
Old Oct 18, 2005 | 02:10 PM
2kjettaguy's Avatar
Use 5356 rod, it takes more heat to melt and will force the welder to penetrate deeper. Welding a tranny casing is no big deal if you're a pro.
Evan
Old Oct 18, 2005 | 03:21 PM
Default Re: Anyone know what type of aluminum our tranny casings are? (2kjettaguy)
Word he said it was easy, he said it would be really easy if he knew the material. It is a small hole the size of a dime, nothing major like your is/was. ^ there.
Old Oct 18, 2005 | 05:11 PM
WOW nice work...better than doingwhat i said.
Old Oct 18, 2005 | 06:09 PM
speeddave's Avatar
^ that looks more like a brace than a patch, but i could be wrong.
Old Oct 19, 2005 | 05:55 AM
Default Re: Anyone know what type of aluminum our tranny casings are? (speeddave)
it is a brace. it was a little harder to weld than i thought it would be.
Old Oct 19, 2005 | 01:02 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philipwight &raquo;</TD></TR><TR><TD CLASS="quote">i welded my case with er5356 rod and a tig welder.
which case is that? inner or outer section?
Old Oct 19, 2005 | 01:10 PM
snoochtodanooch's Avatar
yea sometimes working with those castings can be a bitch. never really know what is in that type of stuff. honda seems to use reasonable decent stuff, you don't seem em cracking too often for no reason.
Old Oct 19, 2005 | 01:32 PM
Default Re: Anyone know what type of aluminum our tranny casings are? (snoochtodanooch)
It is the bellhousing side.
Old Oct 20, 2005 | 09:09 PM
mrcch's Avatar
The cases are casted just like the blocks and heads. They are all A356 Aluminum Heat Treated to a T6 condition.
Old Oct 21, 2005 | 04:19 AM
RMF
Guest
Posts: n/a
Default Re: (mrcch)
They put titanium dust in the castings so you can't weld it.Without it bubbling up real bad.I would use 4043 because its softer and when it cools it won't try to crack as bad.Those cases are brittle and pull real bad.
Old Oct 21, 2005 | 06:27 AM
Default Re: (RMF)
I didnt have any really bad issues welding the case. i am just a novice welder at that. i just cleaned the case very well.
RamenPoweredDC5
Mar 23, 2011 01:42 PM
DC2_2
Acura TL, RL & ZDX
Dec 12, 2010 05:27 PM
Typlayinu
Dec 8, 2005 09:13 AM
Chileno34
May 4, 2005 08:08 PM
a1320addict
Mar 3, 2005 09:42 PM
