Stroker Kit...Need Crank? Builder GURU'S needed...
Old Oct 17, 2005 | 02:09 PM
Baggy Spandex's Avatar
Default Stroker Kit...Need Crank? Builder GURU'S needed...
Okay...A buddy of mine just recently ran into a set of Crower Rods and JE Pistons. The rods and pistons are for what we are assuming a stroker kit. Now my question is, can he use a stock crankshaft with these part numbers?
<U>JE Pistons #:</U> 225593
BORE: 3.189
COMP. HEIGHT: .967
FORGING: 81MM
PIN DIA.: .787
PIN LENGTH: 2.250
DOME: .135
<U>Crower Rods #:</U> B93723B-4
The rods look pretty long...but the piston looks abnormally short..which leads me to believe that the crank is optional b/c its a forged unit???
Old Oct 17, 2005 | 09:20 PM
Default Re: Stroker Kit...Need Crank? Builder GURU'S needed... (OneFiveAlive)
ttt
Old Oct 17, 2005 | 10:53 PM
cptengineer's Avatar
sorry dude whet through the calculations and you will need a 92mm crank. if you go stock then the piston will sit way below the deck. however i think scat stocks that crank size. also the rod bearings will have to be LS.
Old Oct 30, 2005 | 01:21 AM
Thanks for the input...
bump for any definites....
Old Nov 1, 2005 | 07:02 AM
Jeeze...no love from the engine builders
Old Nov 1, 2005 | 09:54 AM
CHEETAH's Avatar
yeah what he said ... 967 comp height is offset to work with a 92 crank and stock ls length rod.
Endyn carries the crower 92mm crank and rods and pistons, check with them for the crank, email staff@theoldone.com
i use the crower 92mm crank modified by Endyn on my build.
greg
Old Nov 1, 2005 | 12:02 PM
Default Re: Stroker Kit...Need Crank? Builder GURU'S needed... (CHEETAH)
cool cool, thank you much sir
prodragEG
Jun 8, 2008 08:54 PM
fmfkid250
11
Nov 29, 2006 05:58 AM
ITRnorway
Aug 12, 2006 02:08 AM
DEMNTD1
17
Oct 10, 2005 08:47 PM
altoid
Feb 22, 2003 08:04 AM
