oil pressure sensor..autometer..?
Old Oct 17, 2005 | 12:40 PM
EikoU's Avatar
Default oil pressure gauge sensor..autometer..?
last night im at a light and i saw my oil pressure drop to 0 so i shut the car off rite away and let it roll bak..all my oil leaked out the motor..so my brother pushed me wit his van to my dads parking lot and the oil pressure sensor from autometer broke off the back of the block and let all the oil out and im just hoping i didnt *** up the motor..Has this happened to anyone on here? my mechanic said the vibrations from the motor might have caused the brass fitting for the sensor to snap but i dont think thats wat happend..maybe it was installed wrong? now part of the brass fitting is stuck in the block and its sticking out a little but i can't figure out of how to get it out..any ideas?
Old Oct 17, 2005 | 01:08 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: oil pressure gauge sensor..autometer..? (bxjdmhatch)
vibrations broke it... its happened before
Old Oct 17, 2005 | 02:06 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: oil pressure gauge sensor..autometer..? (wantboost)
it is alot of weight hanging off of the back of the engine. you need a screw extractor set to get the rest of it out.
Old Oct 17, 2005 | 02:15 PM
Mista Bone's Avatar
D Tranny Guru
and here is the cure...........
Old Oct 17, 2005 | 02:30 PM
Jwbetley's Avatar
Default Re: (Mista Bone)
be thankfull that you had an eye on that gauge
Old Oct 17, 2005 | 08:28 PM
EikoU's Avatar
thanks for the replies and the diagram..
anyone have pictures of how they have theirs hooked up on their car?
Old Oct 17, 2005 | 08:42 PM
rhd's Avatar
rhd
anyone have issues wiht the autometer senders dying?
every one that i know of didn't last for more than a month on anyones cars. ****, mine lasted like 20 min
Old Oct 17, 2005 | 10:35 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bxjdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">..Has this happened to anyone on here? </TD></TR></TABLE>
Haha, good one. Do a quick search - no one threads the sender into the block anymore - that's a big no-no that's been burned into our brains.
Old Oct 17, 2005 | 11:18 PM
AlphaQup's Avatar
subscribed cause im bout to do this too. I'm a visual guy, so wheres the pics at guys?
Old Oct 18, 2005 | 02:22 AM
EnzoSpeed's Avatar
Default Re: oil pressure gauge sensor..autometer..? (AlphaQup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup &raquo;</TD></TR><TR><TD CLASS="quote">subscribed cause im bout to do this too. I'm a visual guy, so wheres the pics at guys?</TD></TR></TABLE>
Huh? What do you want from us?! This has been covered a billion times.
Brass is soft. It breaks under stress. So don't hang your brass sender off of your block .
What more do you need? All you do is secure the sender to your firewall, then run a line to it from the block.
Ex:
Old Oct 18, 2005 | 07:52 AM
Mista Bone's Avatar
D Tranny Guru
Autometer sender die when mounted to the block on our 4 cylinders.
BTW a 1.5" conduit mount will mount the sender nicely to the firewall.
Old Oct 18, 2005 | 08:38 AM
TurboTagTeam's Avatar
^^I ran that on my car. Worked nicely
Old Oct 18, 2005 | 04:59 PM
rhd's Avatar
rhd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">Autometer sender die when mounted to the block on our 4 cylinders.
BTW a 1.5" conduit mount will mount the sender nicely to the firewall.</TD></TR></TABLE>
mine WAS mounted to the fire wall wiht a 1.5" conduit mounter and -6an braided line...and it died the first time the same day i put it on, and the 2nd sender worked for a week
Old Oct 18, 2005 | 06:19 PM
EikoU's Avatar
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">
mine WAS mounted to the fire wall wiht a 1.5" conduit mounter and -6an braided line...and it died the first time the same day i put it on, and the 2nd sender worked for a week</TD></TR></TABLE>
The sender from autometer lasted 2 weeks working in my car mounted onto the block b4 it broke off..do u think the sender u were using died out due to the -6an braided line being too big or small?
Old Oct 18, 2005 | 07:07 PM
EnzoSpeed's Avatar
Default Re: (bxjdmhatch)
You goofs are confusing yourselfs because some of you aren't on the same page.
Issue #1: Some of you are saying the sender "died" when you attached it to the block. That means it broke off. ALWAYS REMOTE MOUNT YOUR SENDERS. That's really beating a dead horse.
Issue #2: Some of you are saying the sender "died" because it stopped working. This seems to happen quite often - Autometer is known for sucking. I'm not sure if their senders are actually low quality or if we just hear about it happening more often because most people buy Autometer gauges. Whatever the reason, I think that Autometer has a warranty of some sort and will replace the bad senders.
Old Oct 18, 2005 | 07:14 PM
nota-eg's Avatar
Default Re: (EnzoSpeed)
I am about to use a sandwich adapter plate for my turbo feed. Will a brass fitting with a hose-fitting on the end be okay?
Is it just the heat+weight that kills them or is it just the heat?
Old Oct 18, 2005 | 07:56 PM
EnzoSpeed's Avatar
Default Re: (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">I am about to use a sandwich adapter plate for my turbo feed. Will a brass fitting with a hose-fitting on the end be okay?
Brass fittings are fine. It's the senders that are the problem because they are heavy.
But I'm telling you - DON'T use a rubber feed line. GET SOME SS LINE. The rubber line is going to leak at the ends where it is clamped. Plus, you don't want a rubber line next to all that hot exhaust stuff - if it melts through, you're f'ed.
If you INSIST on using a rubber feed line (don't do it!) then you should at least get some small scale t-bolt style clamps. You can't use a regulat Home Depot worm-gear clamp because it will pinch the hose as it tightens and you'll have a leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Is it just the heat+weight that kills them or is it just the heat?</TD></TR></TABLE>
It's the weight + vibration. Brass is really soft. This will sound like a lame analogy, but imagine holding a soft cookie in your hand and then shake your hand up and down really fast. The end of the cookie will start to break off in a jagged pattern - that's what the brass looks like when it breaks.
Old Oct 18, 2005 | 08:02 PM
TurboCoop's Avatar
I have my little plastic oil line going straight from my oil distribution block to my in dash guage. I know its not safe, but its lasted 2.5 years so far with no problems. (knocks on wood)
Old Oct 18, 2005 | 08:41 PM
Civicman86's Avatar
where can you get a short amount of SS line for this purpose. I need to redo mine and mount the send on the wall.
Old Oct 18, 2005 | 09:04 PM
EnzoSpeed's Avatar
Default Re: (Civicman86)
You can buy a 20" AN-3 line with non-swivel ends for about $20 (shipped) on ebay.
Old Oct 18, 2005 | 09:41 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">where can you get a short amount of SS line for this purpose. I need to redo mine and mount the send on the wall.</TD></TR></TABLE>
Stan @ Fast-Turbo, where else.
Old Oct 19, 2005 | 08:00 AM
rhd's Avatar
rhd
i always get my SS line from Muscle Motorsports......but, they're local to me
Old Oct 19, 2005 | 08:45 AM
turboH22Aakkord's Avatar
Default Re: oil pressure gauge sensor..autometer..? (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">
Ex:
hey, where did you get that adapter piece with the stock pressure sensor on it? i found it once on a site, but i cant member where it was... thanks man...
Old Oct 19, 2005 | 01:11 PM
nota-eg's Avatar
Thanks a lot Enzo. I'll definately be getting SS lines as soon as I can.
Old Oct 19, 2005 | 02:52 PM
chitownrida's Avatar
i think this is the one:
http://www.stealthmodeperforma...shtml
