ls/vtec-Turbo Oil Lines Is this right (pics)
Old Oct 17, 2005 | 11:52 AM
LaXcAt's Avatar
Default ls/vtec-Turbo Oil Lines Is this right (pics)
is this the correct way to run ls/vtec oil lines? i have a double tee one for head/turbo/pressure sender
yes i know the tee goes where the sender is just want to make sure before i teflon it all up.
is there any where else to run to turbo line so it isnt so long and looks a little better
Old Oct 17, 2005 | 11:59 AM
MooreBoost's Avatar
Default Re: ls/vtec-Turbo Oil Lines Is this right (LaXcAt)
I would get a firewall distribution kit for that.
Old Oct 17, 2005 | 12:01 PM
null.'s Avatar
Default Re: ls/vtec-Turbo Oil Lines Is this right (MooreBoost)
yeah that's right but there is alot of stress on it, so it's going to break, either get the firewall kit, or a sandwich plate
Old Oct 17, 2005 | 12:06 PM
khoalie's Avatar
Default Re: ls/vtec-Turbo Oil Lines Is this right (eg6junkie)
yeah that is the correct way to run it, but junkie and moore are right, that would have a good chance of snapping out of your block or the block itself. i would def get a sandwhich plate, i think they are cleaner than a firewall kit, although pricey. you could also run your turbo oil feed on the tranny side under the dist. there is already a jumble over there so it wouldn't be that noticable
Old Oct 17, 2005 | 12:09 PM
mtber's Avatar
+3 on the sandwich plate
Old Oct 17, 2005 | 12:13 PM
LaXcAt's Avatar
what does the firewall distribution do? does it move the tees away from the block
in the kit i got another line about 6 inches long that i didnt use, is that supposed to come out of the block into the T
....thanks 4 posting
Old Oct 17, 2005 | 12:20 PM
vaporboy12's Avatar
yes just bring a line off the block and bring that to the tee's. when i did mine i used a 6an line. those fitting will snap in the block.
Old Oct 17, 2005 | 01:13 PM
GWInquisitor14's Avatar
Default Re: ls/vtec-Turbo Oil Lines Is this right (vaporboy12)
golden eagle sandwhich adapter
Old Oct 17, 2005 | 01:29 PM
ArinX's Avatar
Default Re: ls/vtec-Turbo Oil Lines Is this right (GWInquisitor14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote">golden eagle sandwhich adapter </TD></TR></TABLE>
worth every penny
Old Oct 17, 2005 | 01:38 PM
Vp Special K's Avatar
Default Re: ls/vtec-Turbo Oil Lines Is this right (ArinX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX &raquo;</TD></TR><TR><TD CLASS="quote">
worth every penny</TD></TR></TABLE>
agreed
Old Oct 17, 2005 | 02:29 PM
TurboCoop's Avatar
Default Re: ls/vtec-Turbo Oil Lines Is this right (Vp Special K)
heres my firewall mounted oil distribution setup. Its a Mr.Gasket fuel dist. block, but it works fine for oil, and its only like $20.
AbitAvenger
Apr 24, 2009 11:31 PM
boostincoupe
Jun 13, 2008 05:15 AM
jfoster
Mar 14, 2005 08:33 PM
VacantBanana
Apr 15, 2004 04:33 PM
