why does the tachometers on the accords move so fast when the transmission shifts
i have noticed when the transmission shifts on the accords the tachometers make a sharp fast movement to a new rpm reading. is it because of the design of the tachometer, or the signal unit. i think it is very cool because a lot of others cars tachometers don't move as quickly. i wonder if honda designed it that way for a reason.
It has to do with dampening of the gauge movement (which is incorporated in other gauges as well), not just the tachometer.
Honda seems to have it down to a science, their gauges are pretty sensitive.
It's a fine balancing act between damping out vibrations and wild swings of the gauge needles. You certainly don't want a Tachometer that's slow to react.
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gianinline »</TD></TR><TR><TD CLASS="quote">Hondas are the best.... they invented "accord"... made V-TEC,.. we as owners... rest this case...
I love my hondas and everything made my them!</TD></TR></TABLE>
Ummm... ok.
Ummm... ok.
you are gay
are you talking about new ones??...throttle by wire perhaps?
you are gay
You'll notice I said sensitive, not accurate.
No, just kidding. The tachs in the three CD720's in the driveway are within 50/150 rpm of a hand held tach I've got.
P
Noods note: ever wonder why they don't calibrate (either gallons (fuel) or (or Deg f (temp) gauges?
P
Cameron60
May 7, 2007 09:08 AM
