COMPRESSION TEST ON JDM B18C ITR
Old Oct 17, 2005 | 10:59 AM
dajman94's Avatar
Default COMPRESSION TEST ON JDM B18C ITR
I did my test and got these numbers....and this is without the butterfly valve at wide open throtle
Cylinder 1- 215
Cylinder 2- 200
Cylinder 3- 220
Cylinder 4- 205
Are these o.k. cause they're all within 10% of eachother?
Would these be in the "normal" 230-240 range with WOT?
let me know guys...thanks
Old Oct 17, 2005 | 11:05 AM
lil GreenGoblin's Avatar
Default Re: COMPRESSION TEST ON JDM B18C ITR (dajman94)
my friend tested his the other day and he was at 230 across the board. but my friend with a fully build gsr tested his it was at 280. i thing you might have a different headgasket.
Old Oct 17, 2005 | 11:36 AM
. O M E G A's Avatar
3rd g3aR vTak
I would get a bore scope . And do a leak down test . Cuz the 200 in #2 could turn into 180 in no time .
Old Oct 17, 2005 | 11:47 AM
dajman94's Avatar
Default Re: COMPRESSION TEST ON JDM B18C ITR (omega02379)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega02379 &raquo;</TD></TR><TR><TD CLASS="quote">I would get a bore scope . And do a leak down test . Cuz the 200 in #2 could turn into 180 in no time .</TD></TR></TABLE>
how much would a bore scope cost and how difficult is a leak down test?
Old Oct 17, 2005 | 11:50 AM
3rd g3aR vTak
If you have decent hearing and a compressor with some decent output , you can do a leakdown test . But to buy a leakdown tester or a bore scope , I hope you didn't spend all your money on that motor . Try Craftsman and Mac tools .
Old Oct 17, 2005 | 12:06 PM
dajman94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega02379 &raquo;</TD></TR><TR><TD CLASS="quote">If you have decent hearing and a compressor with some decent output , you can do a leakdown test . But to buy a leakdown tester or a bore scope , I hope you didn't spend all your money on that motor . Try Craftsman and Mac tools .</TD></TR></TABLE>
I didn't spend all my money on the motor....i bought the car with the motor alreay in it .......how do i do the leak down test with a compressor, cause i have one, and GOOD HEARING
Old Oct 17, 2005 | 12:23 PM
Sean Juan's Avatar
Here's a good tutorial:
http://www.c-speedracing.com/h...n.php
Old Oct 17, 2005 | 12:29 PM
dajman94's Avatar
Default Re: COMPRESSION TEST ON JDM B18C ITR (GRIP KING)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRIP KING &raquo;</TD></TR><TR><TD CLASS="quote">Here's a good tutorial:
http://www.c-speedracing.com/h...n.php</TD></TR></TABLE>
Thanks....it is greatly appreciated
Old Oct 17, 2005 | 12:41 PM
spoonek9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dajman94 &raquo;</TD></TR><TR><TD CLASS="quote">I did my test and got these numbers....and this is without the butterfly valve at wide open throtle
Cylinder 1- 215
Cylinder 2- 200
Cylinder 3- 220
Cylinder 4- 205
let me know guys...thanks </TD></TR></TABLE>
Before you waste time and money on a leak down test, why don't you do the compression test right??? Doing any test half-*** isn't going to tell you anything!!!
Old Oct 18, 2005 | 08:54 AM
3rd g3aR vTak
I didn't spend all my money on the motor....i bought the car with the motor alreay in it .......how do i do the leak down test with a compressor, cause i have one, and GOOD HEARING </TD></TR></TABLE>I would of answered this sooner , but for some reason . . . . it got sent to my spam folder ? Well you need something that can thread into your sparkplug holes AND hook up to a copressor nozzle . GOOD LUCK !!! I didn't see the link . Forgive before you flame !
Old Oct 18, 2005 | 09:43 AM
JOEY F.'s Avatar
Default Re: COMPRESSION TEST ON JDM B18C ITR (spoonek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">
Before you waste time and money on a leak down test, why don't you do the compression test right??? Doing any test half-*** isn't going to tell you anything!!!</TD></TR></TABLE>
Def do it again at WOT. Your values may change significantly.
Old Oct 18, 2005 | 11:02 AM
doublejz's Avatar
Default Re: COMPRESSION TEST ON JDM B18C ITR (jdmcrxb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrxb16 &raquo;</TD></TR><TR><TD CLASS="quote">my friend tested his the other day and he was at 230 across the board. but my friend with a fully build gsr tested his it was at 280. i thing you might have a different headgasket.</TD></TR></TABLE>
280 thats probably like close to 11.5:1-12:1 comp.
Old Oct 18, 2005 | 12:25 PM
dajman94's Avatar
Default Re: COMPRESSION TEST ON JDM B18C ITR (doublejz)
alright im gonna do it again but with WOT...thanks guys...and ill keep you posted
sik96teg
Feb 29, 2008 06:36 AM
dajman94
Oct 17, 2005 12:45 PM
SikITR01-248
Apr 24, 2005 03:46 PM
lazy bum shaughn
Jan 28, 2003 07:55 PM
AL
Nov 26, 2001 05:35 AM
