95 accord lx w/ rear disc??
Old Oct 17, 2005 | 10:27 AM
bostoncal's Avatar
Default 95 accord lx w/ rear disc??
Hi,
Just purchase a 95 Accord Coupe Lx this past weekend and was shock to see it came with rear disc and a sunroof... I though sunroof only came in EX model...can someone fill me in on this? Thanks
Old Oct 17, 2005 | 10:28 AM
jokestar's Avatar
yes accords have front and rear discs = ABS
sunroof, as far as i know, was offered with lx and ex.
Old Oct 17, 2005 | 11:09 AM
i20ar's Avatar
Default Re: 95 accord lx w/ rear disc?? (Este_Cara)
i also thought it was only the ex model.. can some one confirm this .. maybe its a rear disk conversion...
Old Oct 17, 2005 | 11:18 AM
Slunk's Avatar
Default Re: 95 accord lx w/ rear disc?? (Dj14aZnS)
Which engine to you have? Ex's have f22b1 (vtec) and Lx's have the f22b2 (non-vtec). I thought that sunroofs, rear disc brakes, and abs were only available on the EX.
Old Oct 17, 2005 | 12:10 PM
bostoncal's Avatar
^^^ i have the lx f22b2 (non vtec) and yes it came with sunroof and rear disc with abs. Even the emblem still say accor lx on the trunk..did i just get lucky?
Old Oct 17, 2005 | 12:11 PM
P_Adams's Avatar
For the 1995 model year, Both the LX AND the DX were available with four (4) wheel disc brake ABS as an option. The EX came standard with Four (4) wheel disc brake ABS.
Direct from the Honda On-Line Parts Catalog.
P
Old Oct 17, 2005 | 12:14 PM
bostoncal's Avatar
thanks P_Adams..I guess the sunroof was extra also.
Old Oct 17, 2005 | 04:49 PM
ts94acc's Avatar
Default Re: (Este_Cara)
I have a 94 lx with rear disc brakes and a sonroof, but I think the sunroof may be aftermarket. Although it looks like a factory sunroof
Old Oct 17, 2005 | 06:16 PM
P_Adams's Avatar
Default Re: (ts94acc)
The factory sunroof (with it's own seperate roof panel) can be distinguish from aftermarket add-on types by this:
The factory unit has NO outside molding (or flange) around the opening. When open, the factory unit will have a rolled roof edge 90deg, dropping 1/4 to 3/8" . The glass panel raises (when closing) flush with the roof panel. The inside is finished off by a 3/4" felt piping which surrounds the opening.
The aftermarket units can most times be identified by a definite metal flange on both the inside and outside.
To be honest, I've never seen an aftermarket sunroof on a Honda.
P
Old Oct 17, 2005 | 06:27 PM
HondaTechPro's Avatar
Fast way to know for sure.... although I think we have already determined it is an LX... is look at the 7th digit of the VIN:
2=DX
3=LX
4=LX with ABS
5=EX
6=EX with Leather Seats
As for the sunroof.... it was an option as P stated.
Old Oct 17, 2005 | 06:35 PM
BLKFLSH's Avatar
Default Re: 95 accord lx w/ rear disc?? (HondaTechPro)
They had factory sunroofs on lxs?
Old Oct 17, 2005 | 06:39 PM
Default Re: 95 accord lx w/ rear disc?? (BLKFLSH)
Maybe.... maybe it is aftermarket... not really sure.
Old Oct 17, 2005 | 07:37 PM
BLKFLSH's Avatar
I always thought, if it has a factory sunroof it has to be an EX. Would there be any way to get a factory sunroof installed after purchase? Seems like that would be impossible. Or close to imposible.
Old Oct 18, 2005 | 08:50 AM
RUBZERK's Avatar
My 95 lx with ABS has rear disc
My 96 lx w/o ABS does not have rear disc
Old Oct 18, 2005 | 09:08 AM
P_Adams's Avatar
You could order, or find on the lot any Accord (DX,LX or SE with a factory sunroof as long as it was initiated with the "build order" (Stock unit) or Special Order (Customer Sale) so it could be scheduled thru the factory assembly plant. Factory Sunroofs will never be Dealer Installed; since they involve a distinctly different Roof Panel (not only the opening, but unique mounting points for the sunroof assembly, it's drain hoses and the unique headliner panel as well. In addition, there is additional reinforcement in the "A' Pillar to compensate for the weakened roof panel (it's now got a hole in it! )
In order to get a factory Sunroof onto a car not specifically built for it, you would have to cut off a roof with a sunroof at the pillars and graft it onto your car.
Old Oct 18, 2005 | 01:29 PM
Obsidian's Avatar
Default Re: 95 accord lx w/ rear disc?? (P_Adams)
My 94 LX has four wheel disc brakes and ABS. I feel the envy of people who wish they had my brake setup.
Old Oct 18, 2005 | 01:45 PM
RnEpmc's Avatar
Default Re: 95 accord lx w/ rear disc?? (Obsidian)
i assume if your car has an after market sunroof/moonroof then it would open to the outside. my 94 ex came with a sunroof and it gooes into the roof.
Old Oct 18, 2005 | 02:27 PM
P_Adams's Avatar
Yeh, until the point where you have to have the ABS module rebuilt.
Four wheel disc is the cats meow, until the rear calipers sieze up. (another thread)
Now If I could only find a non-ABS 4 wheel disc set-up.
I hate relying on a computer to do my job. I've seen too many "it just kept going" intersection accidents with ABS to be happy with it.
P
dansaleen_04
Feb 14, 2011 02:27 PM
Randolphjo
Suspension & Brakes
15
Oct 10, 2009 01:13 AM
grandtheftlunchbox
Aug 17, 2008 01:29 AM
GapxGuy
10
May 27, 2006 06:18 PM
SpoonFedHatch
Dec 10, 2003 09:48 AM
