rite up camber/ingalls??? help???
hey my integra front tires lean in pretty bad. I know i need a camber kit... so i started to look for one and i found camber kits and ingalls camber kits... they dont llok the same so i dont know which one i need? are they diferent? help please i need to fix this so i stop eating tires
also a good how to install write up would help a lot thanks
some are used to hold the upper control arm and move the stock control arm in and out others are used to move the upper ball joint in and out others use lowering ball joints to adjust for yours i would go with either skunk2 or omni powers upper control arm with adjustable and if you dont know how to intall them as in never taken your suspension off id take it to a professional because you need to get it aligned immediatly afterwards
bake1782
May 9, 2008 08:06 AM
6doorsentra
19
Jul 10, 2007 11:11 AM
..::91TEG-G2::..
May 23, 2004 01:53 PM
