quick bseries head pulling question (bolt order)
Old Oct 17, 2005 | 06:52 AM
turbotime's Avatar
Default quick bseries head pulling question (bolt order)
Hey I just read the post on how to replce a bseries HG, and i have a question about the step with the 2 sets of 10 bolts, the ones holding the cams in (12mm i believe).
Anyway I know your supposed to remove them in an order, but is the order is:
1 7 9 5 3
4 6 10 8 2
image by JDMlyfestyle:
so there are 10 "order numbers" and 20 bolts... so im confused. Do I do them in pairs, or so i do the bolts on each rail, or one rail at a time?
Thanks just a lil confused and dont wanna warp anything.
Old Oct 17, 2005 | 06:56 AM
dc2vu's Avatar
i beleive those arent the bolts that are bolting the head the the block...but i dont know
Old Oct 17, 2005 | 06:58 AM
turbotime's Avatar
no they arent.. the hold the cams but they still need to be removed in some certain order according to his post...
Old Oct 17, 2005 | 07:26 AM
dpetro1's Avatar
Default Re: (turbotime)
yeah im pretty sure the bolt pattern is for each rail individually. PM the guy that made the post im sure he can help you out
Old Oct 17, 2005 | 08:24 AM
aspec101's Avatar
Default Re: (dpetro1)
first off to take off a b series head you need to REMOVE the cams! then you can proceed to use that sequence, also do it in 3 steps.
Old Oct 17, 2005 | 08:58 AM
Luserkid's Avatar
Default Re: (vaperformance)
Your suppose to do it with first set up 10 (intake side) then 2nd set of 10 (Exhaust side) thats why your seeing it as 20 instead of 10. Then you do the 3rd set which are the head bolts themselfs.
Old Oct 17, 2005 | 10:04 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaperformance &raquo;</TD></TR><TR><TD CLASS="quote">first off to take off a b series head you need to REMOVE the cams! then you can proceed to use that sequence, also do it in 3 steps. </TD></TR></TABLE>
yeah he is taking about the cam caps or whatever to get to the cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Your suppose to do it with first set up 10 (intake side) then 2nd set of 10 (Exhaust side) thats why your seeing it as 20 instead of 10. Then you do the 3rd set which are the head bolts themselfs. </TD></TR></TABLE>
^^^what he said
Old Oct 17, 2005 | 10:18 AM
turbotime's Avatar
Default Re: (Luserkid)
exactly what i was asking! thanks!
JWILD
Sep 23, 2011 02:15 PM
Honda owner
May 30, 2006 02:17 PM
2muchPSI
Dec 28, 2002 05:45 PM
quikrpm'z
Jul 9, 2001 09:43 AM
