occasional knock/click?? funny idle?? H22a4 EG
Old Oct 17, 2005 | 06:43 AM
jmayhew's Avatar
Default occasional knock/click?? funny idle?? H22a4 EG
92 Vx with a H22a4 Hasport mounts.
except idle & random/occasional knocking sound car seems to be running fine.
no codes, vtec is working.
as fas as the idle...it idles around 800...for about 30sec-1min then it drops to almost stalling out..bounces back & forth between 100-800 for about 10-15sec then comes back up to a steady 800 for about 30sec-1min & does it all again.
IAC seems to be pretty clean ...have played with idle screw.
can't figure it out.
now this sound isn't constant...it will make the noise for about 30sec-1min & then stops...& when it happens is random
it sounds like is coming from the timebelt?? belt lash? belt rubbing the cover?
one thing we did mess up was we found out there was too much oil in the car for about 100-150miles of use..probably about 6-7qts?..that plus a bad valve cover gasket caused some oil leak.
would this have cause a problem.
maybe oil got over onto the cam gears & belt & causing a problem?
anyone seen/hear/or have this problem.
Modified by jmayhew at 8:28 AM 10/17/2005
Modified by jmayhew at 8:33 AM 10/17/2005
Old Oct 18, 2005 | 11:16 AM
jmayhew's Avatar
Default Re: occasional knock/click?? funny idle?? H22a4 EG (jmayhew)
after doing a ton of research....seems like its the auto tensioner for the timing belt
jmayhew
Oct 18, 2005 12:06 PM
3.3.3
Sep 22, 2004 09:38 AM
DIE DIE
Mar 22, 2004 01:33 PM
DIE DIE
Mar 21, 2004 12:35 PM
