who here has jun3s... and what fuel pressure do you run
Old Mar 5, 2002 | 10:43 PM
Mr. Softee's Avatar
Default who here has jun3s... and what fuel pressure do you run
Do not tell me to dyno, i cannot. I will once i can, but for the time being i cannot. I need just a temporary fuel pressure, until I do something about my block, for the street. Im running 50 with fuel line on right now, it seems okay. I am running a skunk2 chipped ecu btw. from joecash.
Old Mar 6, 2002 | 04:42 AM
Mike K's Avatar
Default Re: who here has jun3s... and what fuel pressure do you run (94goldjungsr)
on my motor, I'm running 50psi on 310cc injectors w/ stock fuel pump.
mike m. has 60psi on 310s on stock pump. he has 440cc injectors and a toyota supra fuel pump on the way. hondata will make it idle like butter.
if you have stock injectors, crank it. like 55psi+
Old Mar 6, 2002 | 04:44 AM
slowerthanu's Avatar
New User
Default Re: who here has jun3s... and what fuel pressure do you run (Mike K)
I am running type-3's and 51 PSI of fuel pressure. I am still running rich (I also have the JUN ECU if that makes a differance). I may have to lean out the top-end with my V-afc when I hit the dyno next week.
Old Mar 6, 2002 | 05:48 AM
canuck-mx6's Avatar
Hey Mike K
I realise that I need to upgrade my stock 240 CC/min injectors, what do you suggest, the 310's or the 440's? I using hondata with my Jun 3's.
In the meanwhile, what is the highest fuel pressure that I can run on the stock injectors without risking injector failure. I know that the boosted guys run upwards of 100 PSI with an fuel pressure riser, so I am assuming that 60 PSI will be fine until the new injectors come in.
Old Mar 6, 2002 | 06:33 AM
Mike K's Avatar
Default Re: who here has jun3s... and what fuel pressure do you run (canuck-mx6)
60-65psi is not a problem.
Old Mar 6, 2002 | 06:59 AM
SIINSI's Avatar
Would you say that 50 PSI on stock injectors is inadequate? Is it necessary to upgrade from stock and will there be any performance gains?
Miguel
[Modified by SIINSI, 8:15 AM 3/6/2002]
Old Mar 6, 2002 | 07:25 AM
JDM_DOHC_SiR's Avatar
New User
Ya but at that pressure that pumps is getting squeezed like a Pimple heheee
Old Mar 6, 2002 | 07:35 AM
azn98R's Avatar
Default Re: who here has jun3s... and what fuel pressure do you run (JDM_DOHC_SiR)
Are you saying the fuel pump should be replaced... by the way I am running 70 psi w/ stock injectors and pump.... I need a upgrade any suggestions????
Old Mar 6, 2002 | 07:54 AM
Mike K's Avatar
Default Re: who here has jun3s... and what fuel pressure do you run (azn98R)
Get some 310s. They will deliver the same amount of fuel you're getting now at a lower pressure. Probably like 45psi or so.
Old Mar 6, 2002 | 08:10 AM
canuck-mx6's Avatar
I just purchased some 440's from Boosted Hybrid......I know that the Hondata can make the idle stock even though these are huge compared to the stock 240's. I should be able to keep the fuel pressure at stock with these......
Old Mar 6, 2002 | 01:14 PM
Mr. Softee's Avatar
****** a. im gonna boost it up to 65 today and see how it feels.
Old Mar 6, 2002 | 03:18 PM
scooter's Avatar
when I ran 60psi on my stock injectors the pressure fell off to 55psi around 5000rpm. The stock fuel pump can only handle 55max, at least on my car. I got prelude injectors in my car with JUN 2's and it runs plenty of fuel.
scott
Old Mar 6, 2002 | 05:20 PM
SIINSI's Avatar
Default Re: who here has jun3s... and what fuel pressure do you run (scooter)
what happens when you push the pump too far? I think I may be having this problem....
Miguel
Old Mar 6, 2002 | 05:28 PM
infinkc's Avatar
Default Re: who here has jun3s... and what fuel pressure do you run (SIINSI)
im running 280cc prelude injectors @ 49psi with a upgraded fuel pump.
Ruben19
Jan 29, 2006 04:31 PM
endlessdv
Jan 9, 2006 12:47 PM
red civic standard
Nov 15, 2004 05:34 AM
turbosi03
May 27, 2003 06:34 PM
Leo95SE
Jun 24, 2002 01:03 PM
